29487 Discussions
ifort command not found in ubuntu 19.10
jyoti__jyoti
I have installed paralled studio xe 2020 cluster edition in my laptop having OS ubuntu 19.10, but I am constantly getting the error :ifort command not found.
What should I do?
mecej4
In a command shell session, you need to "source" the Intel start-up script ifortvars.sh before attempting to use the Intel Fortran compiler. The details are in the file <install-dir>/documentation_2020/en/compiler_f/ps2020/get_started_lf.htm .
Sampson__Andrew
The path to the command is probably not found in your "path" variable. I'm a user of the "c-shell" shell, so I have included the following in my .cshrc file (found in my home folder):
source /opt/intel/parallel_studio_xe_2020.1.102/bin/psxevars.csh intel64
If you're using the bash shell (default shell in Ubuntu), it should be something similar, but for the "*.sh" version of the variables script. The script contains the necessary environment variables to run the programs you just installed. After including the necessary line in your .cshrc (for c-shell) or .bashrc (bash shell), you'll need to "re-source" the file to load the new settings. Or just log out and log back in.
I hope this helps.
Andrew
JohnNichols
Honored Contributor I
Just out of interest what does the DABR stand for -- that is a new one on me.
