Allocatable array
cmc
With reference to my previous post (https://software.intel.com/en-us/forums/intel-fortran-compiler/topic/844545) I want to send this array out of the routine which reads the file. The problem is that the size of the array (file) can change, so the main routine does not know the size of the array before the file has been read. How do I declare the array in the two routines?
subroutine main(file_name)
    implicit none
    character(len=100), intent(in)      :: file_name
    real(8), allocatable                :: array(:,:)
    call file(file_name, array)
end subroutine
subroutine file(file_name, array)
    implicit none
    character(len=*), intent(in)        :: file_name
    real(8), allocatable, intent(out)   :: array(:,:)
    integer(2)                          :: n_rows, n_columns, i, j, io
    open    (unit = 1, file = file_name, status = 'old')
    read    (1,*) n_rows, n_columns
    allocate(array(n_rows, n_columns))
    read    (unit = 1, fmt = *, iostat = io) ((array(i,j), j = 1, n_columns), i = 1, n_rows)
end subroutine
Cheers,
Carl
Ferdinand_T_
New Contributor II
cmc wrote:
It doesn't work. I get an access violation error...
Without seeing the full program code, it is hard to guess what is going wrong; the snippets you show look fine to me.
If I had to guess, I'd suspect you do not have an explicit interface for the file subroutine -- note that allocatable (deferred-shape) arrays require explicit interfaces -- which can be solved by putting your subroutines into a module and using it in the program.
Kind regards, Ferdinand
Steve_Lionel
You've already done it. As a test, put after the call to file:
print *, shape(array)
You can use ubound(array,1) and ubound(array,2) to get the upper bounds of each dimension.
cmc
JohnNichols
Honored Contributor I
you learn something new every day - perhaps - I did not know this
Ferdinand_T_
New Contributor II
cmc
Thank you Ferdinand! It works now :)
\Carl
David_Billinghurst
New Contributor III
Carl,
I would be helpful if you provided the complete example.  The code fragments you posted do not tell the whole story.
Try this.  Putting the subroutine in a module and using it provides the interface to the calling routine.  This works with the data file from your other post.
io_4.f90
program io_4
  use read_m
  implicit none
  integer n_rows, n_columns
  call readit('file.dat',array)
  n_rows = ubound(array,1)
  n_columns = ubound(array,2)
  write(*,*) array(1,1), array(1,n_columns)
  write(*,*) array(n_rows,1), array(n_rows,n_columns)
end program
read_m.f90
module read_m
contains
  subroutine readit(file_name, array)
    implicit none
    integer n_rows, n_columns, i, j
    open(1,file=file_name,status='old')
    read(1,*) n_rows, n_columns
    read(1,*) ((array(i,j), j = 1, n_columns), i = 1, n_rows)
    close(1)
  end subroutine
end module
