29649 Discussions
Allocatable or pointer attribute missing
awa5114
It seems like every time I try to allocate the dimensions of an array in a subroutine I get the following error message:
Error 3 error #6596: If a deferred-shape array is intended, then the ALLOCATABLE or POINTER attribute is missing; if an assumed-shape array is intended, the array must be a dummy argument.
I do not wish to make a dummy argument. This array is local and needs to stay within the subroutine. Therefore I am left with the first option. Yes this is a deferred shape array and that is the intent. Do I need to add an intent statement to the declaration? How can I get the array to carray the allocatable attribute?
awa5114
Nevermind, I got it. The declaration must explicitly state that the array is in fact allocatable as follows:
double precision, dimension(:,:),allocatable :: ArrayName
andrew_4619
real(dp), allocatable :: ArrayName(:,:)
It is mainly a style thing but the dimension attribute is largely superfluous these days. "Double precision" is also rather old hat, the "modern" way is to use REAL of a specific KIND.  This is more flexible in that you can then easily change the real kind
jimdempseyatthecove
Not when you wish to apply the array shape to multiple arrays:
double precision, dimension(:,:),allocatable :: ArrayName. BrrayName, CrrayName
Jim Dempsey
andrew_4619
Jim Dempsey
True, I did say " mostly". The usage I object to most is when the dimension statement is on a separate line and even worse seperated several lines from the type declareration. Do be honest I wouldn't lose any sleep if dimension was deleted from the language and I would bet if the language was being defined today it would not exist.
FortranFan
Jim Dempsey
Since Andrew's comment was in connection with style, readers may want to note there is growing consensus from a style perspective in the programming community spanning different languages and paradigms to have only
    one variable per declaration
Some quick links on this view include Google Java Style Guide and C++ for Programmers, etc.
Given all the attributes one can tack on to variable declarations in Fortran, I suggest the same style and avoid statements such as
andrew_4619
I would agree with FF. Whilst I don't religiously follow one variable per declaration I do follow that rule for the most part particularly so with dummy args as it give much more clarity to see things at a glance IMO and also the option to tag a comment on the end .
