29423 Discussions
Allocating parametrized declared type that is within a parametrized declared type
AThar2
I have the following code which gives me a catastrophic error without mentioning what the error is:
catastrophic error: Internal compiler error: segmentation violation signal raised Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
However, I know what triggers this error, namely: allocate(gdad% ttt(tsize=10) :: gdad% test_type)
Anybody familiar with this
  module t_test
     implicit none
     type ttt(tsize)
        integer, len :: tsize
        real x(tsize)
     end type ttt
  type :: t_rndom_diameter(t_rsize,t_csize)
      integer, len :: t_rsize,t_csize
      real :: x(t_rsize,t_csize)
     type(ttt(tsize=:)), allocatable :: test_type
  end type t_rndom_diameter
  end module t_test
  program p_test
  USE t_test
  implicit none
  type(t_rndom_diameter(t_rsize=3,t_csize=3)) :: gdad
  allocate(gdad% ttt(tsize=10) ::  gdad % test_type)
  end program
Thanks in advance
AThar2
Just an update, I think I know why now.
The issue is: allocate(gdad% ttt(tsize=10) :: gdad % test_type), which instead should be
allocate(ttt(tsize=10) :: gdad % test_type)
Juergen_R_R
Valued Contributor II
An internal compiler error is always an error, so please report this to the Intel support. The ICE seems to be present since at least v17 of the compiler. Nagfor and gfortran both complain that gdad resp. ttt are not derived type members, which indeed they aren't. Indeed your modified code compiles both with ifort and gfortran, and seems to be a correct allocation to me.
AThar2
I will file in a report to the support team now. Thanks!
