29649 Discussions
Another bug with IMPORT and SELECT RANK
OP1
New Contributor III
Those posts are turning into an unhealthy obsession with IMPORT these days! A colleague stumbled on the following, which clearly is a compiler bug.
When compiled (as is), the compiler (2024.1.0, both ifx or ifort) returns the message "error #6606: The block construct names must match, and they do not. [SRNK1]"
They DO match, haha.
The code shows how to make that bug go away, and oddly it involves IMPORT again - maybe there is something more serious lurking behind the scenes here as this seems completely unrelated.
MODULE M
IMPLICIT NONE (TYPE, EXTERNAL)
INTEGER, PARAMETER :: I4 = SELECTED_INT_KIND(9)
INTERFACE
    MODULE SUBROUTINE SUB_M(A)
        IMPORT, ONLY : I4
        INTEGER(KIND = I4), INTENT(IN) :: A(..)
    END SUBROUTINE
END INTERFACE
END MODULE M
SUBMODULE (M) SUB_M
IMPORT, ALL
CONTAINS
! Will compile if you comment the IMPORT, ONLY statement
! and define I4 locally after IMPLICIT NONE (by uncommenting).
! Will also compile if you comment out the select rank block SRNK1.
IMPORT, ONLY : I4
!INTEGER, PARAMETER :: I4 = SELECTED_INT_KIND(9)
SRNK1: SELECT RANK (A)
    RANK (*)
END SELECT SRNK1
END SUBROUTINE SUB_M
END SUBMODULE SUB_M
Devorah_H_Intel
Please test with ifx 2024.2
It has been fixed in that version.
Devorah_H_Intel
andrew_4619
Why are the redundant IMPLICIT NONE (TYPE, EXTERNAL) lines in the routines when it is already module wide?
andrew_4619
Interfaces wasn't part of my point. The implicit statement at line  26 above is redundant as the one at line 18 applies in all the routines in that submodule and given the declaration in the implementation is checked  against the interface  then in effect to applies within the interface also!
OP1
New Contributor III
Your comment regarding the unnecessary duplication of the IMPLICIT NONE statement is correct, technically (because IMPLICIT NONE is the desired behavior for both module and contained procedure in the original post's code), but note that in general a contained procedure can still have its own IMPLICIT statement(s). Consider the example shown below
MODULE M
CONTAINS
    SUBROUTINE S1(I)
    !IMPLICIT REAL (I)  ! This line needs to be uncommented for
                        ! the code to compile.
    WRITE(*, *) I
    END SUBROUTINE S1
END MODULE M
PROGRAM P
USE M
REAL :: I
CALL S1(I)
END PROGRAM P
 Our policy is to avoid having to finesse those IMPORT statements and not try to be clever with them. We require those IMPORT statements everywhere they are allowed - for peace of mind. It seems this is also your strategy, in this thread (https://community.intel.com/t5/Intel-Fortran-Compiler/The-IMPLICIT-NONE-issue-drags-on/td-p/1109569 ) you posted:
@andrew_4619 wrote:
From a personal point of view I put implicit none absolutely everywhere often in a redundant way and that way I feel happy that my trousers will not fall down as I have both belt and braces.
