29386 Discussions
Compiler complains about declaration conflicts and functions not being declared that are
CoryG
I am compiling the following file as part of a much larger project:
subroutine GetSoftwareLicense
    ! Checks out a license for this instance
    use Globals
    use Licensing
    implicit none
    LOGICAL :: CheckoutSuccessful
    !******************* CHECK OUT SOFTWARE LICENSE **********************
    CheckoutSuccessful = initialize_license(1, 50)
    if (.not. CheckoutSuccessful) call NoLicenseExit(3)
    write(szLogText,'("Success!")')
    call GlobalWriter(0,.TRUE.,.FALSE.)
end subroutine GetSoftwareLicense
subroutine NoLicenseExit(iType)
    ! Exits based on there not being a valid license
    use Globals
    implicit none
    INTEGER, INTENT(IN) :: iType
    CHARACTER(100) :: StringLoader
    INTEGER :: iret
    StringLoader = "License Error"//CHAR(0)
    if (iType == 1) iret = MessageBox(ghWindow,"License failed to be checked out."//CHAR(0),StringLoader,IOR(MB_OK,MB_ICONERROR))
! More such checks... Just display a relevant message based on iType
    iret = SendMessage(ghWindow,WM_DESTROY,0,0)
end subroutine NoLicenseExit
integer function GetCostForThreads(threads)
    implicit none
    integer, intent(in) :: threads
    integer, parameter :: baseline = 5
    ! Baseline
    if (threads <= 4) then
        GetCostForThreads = baseline
    ! Scaling
    else
        GetCostForThreads = INT((threads-4)*1) + baseline
    endif
end function GetCostForThreads
logical function UpdateOMPThreadCount(threads)
    use Licensing
    use Globals
    implicit none
    integer :: cost, actual_threads
    logical :: success
    ! Obviously
    if (threads <= 1) then
        actual_threads = 1
    else
        actual_threads = threads
    endif
    ! Get cost
    cost = GetCostForThreads(actual_threads)
    ! Check with licensing
    success = update_cost(cost)
    if (success) then
        call omp_set_num_threads(actual_threads)
    else
        call GlobalErrorHandler(14)
    endif
    UpdateOMPThreadCount = success
end function UpdateOMPThreadCount
When compiling, I get the following error messages:
Severity Code Description Project File Line Suppression State
Error error #6404: This name does not have a type, and must have an explicit type. [GETCOSTFORTHREADS] Licenses.f90
Error error #5508: Declaration of routine 'NOLICENSEEXIT' conflicts with a previous declaration Licenses.f90
Why are these popping up? I have clearly declared GetCostForThreads, and nowhere else have I declared NoLicenseExit. I've tried rebuilding the solution multiple times. I've also tried deleting the entire "Debug" directory. Neither works. These are the only error messages that appear when compiling the entire project.
Labels (2)
jimdempseyatthecove
 >>I have clearly declared GetCostForThreads,
In UpdateOMPThreadCount you have implicit none
You are calling the function GetCostForThreads
Within the scope of UpdateOMPThreadCount, GetCostForThreads is undefined.
A suggestion is to place this code into a module then (elsewhere) use this module:
module YourModuleNameHere
! module data follows
contains
! module procedures follow
end module YourModuleNameHere
subroutine SomeCodeElsewhere
  use YourModuleNameHere
  implicit none
If (when) you cannot place that code inside a module, then create a module containing the interfaces and use that to declare your interfaces:
module YourInterfacesNameHere
interface
end module YourInterfacesNameHere
! other file
subroutine something
   use YourInterfacesNameHere
EDIT: Note, in the second case your subroutine GetCostForThreads will require the USE YourInterfacesNameHere.
Jim Dempsey
TobiasK
@CoryG probably the error is elsewhere in your code / compilation. Any chance that we can get a full reproducer and the full compilation log?
Please also check with the latest release (2024.2).
jimdempseyatthecove
contains
  implicit none
interface
! other file
Jim Dempsey
TobiasK
@jimdempseyatthecove good catch:)
For omp_set_num_threads it would also be better if you would add "use omp_lib". For the GETCOSTFORTHREADS function, you could also declare it as "integer, external :: GETCOSTFORTHREADS"
CoryG
Ah I'd forgotten about "use omp_lib". Thanks!
