29285 Discussions
Another issue on Calling DLL in VS2008
chermeuse
I made the DLL loaded successfully on 32bit platform and it works
well. But when the function of that DLL was finished the VS2008 program was quit. Note: the function of that
DLL was just reading and writing some files on the disk.
cheng
Steven_L_Intel1
I think we need some more details. From which language is the DLL called? Which exact Fortran version are you using? How did you declare the Fortran routine in the language that called the DLL routine?
chermeuse
the DLL is called from VC++ and the fortran version is V11.0.061.
The DLL routine has been loaded successfully. The main problem is that when the Dll routine has finished, the
whole VC++ program stopped which is not expected.
anthonyrichards
New Contributor III
Is there a STOP command in the DLL?
Steven_L_Intel1
Please show the declaration of the Fortran routine in the C++ code and the declaration section of the Fortran routine. Please also show the command line options used to build the DLL (you can get this from the Command Line property page).
The most likely problem is that you have a calling mechanism mismatch that corrupts the stack.
