Another way to avoid the INTEGER OVERFLOW problem
WSinc
The advantage of this method, is:
You don't have to resort to a higher order arithmetic, and you always get the correct result.
integer(8) function two_int(istart,istop,istep)
integer(8) istart,istop,istep,i1m,i2m,i1d,i2d
  i1m=mod(istart,istep)
  i1d=istart/istep
  i2m=mod(istop,istep)
  i2d=istop/istep
  two_int=i2d-i1d+(i2m-i1m+istep)/istep
end function
This method also works for 4 byte quantities.
Or any number of bytes.
Steven_L_Intel1
Bill, let's try to keep it down to a dozen threads on this topic, ok? Use https://software.intel.com/en-us/forums/topic/542848
