Any danger in this sample program?
Yaqi_Wang
MODULE mytype1
TYPE mytype
INTEGER, POINTER, DIMENSION(:) :: ptr
END TYPE mytype
CONTAINS
! rename a to b
SUBROUTINE rename(a, b)
IMPLICIT NONE
TYPE(mytype) :: a
TYPE(mytype) :: b
b%ptr => a%ptr
NULLIFY(a%ptr)
RETURN
END SUBROUTINE rename
END MODULE mytype1
PROGRAM test
USE mytype1
IMPLICIT NONE
TYPE(mytype) :: a, b
INTEGER :: i
! create a
ALLOCATE(a%ptr(100))
a%ptr = 1
CALL rename(a, b)
! then we can use b
DO i = 1, 100
b%ptr(i) = i
ENDDO
STOP
END PROGRAM
I have a large code doing the similar thing. And when I turn O3 on
with Intel Visual Fortran compiler 11.1.054. The code crashes and I am pretty
sure it is the 'rename' subroutine that causes the problem. But I did
not see anything wrong in it. Is there any danger in 'rename' which is
not so obvious?
Reply from Steve Lionel:
It is evident that you retyped in the code as you showed it here, as it
has several syntax errors. When I correct the syntax errors and build
it with /O3 and Intel Visual Fortran 11.1.054 (and 11.1.065), it runs fine.
I conclude, then, that the code you showed here is not representative of
your actual code. Paraphrases and uncompilable excerpts do not help in
getting your problem resolved. Please provide an actual test case.
My answer:
The problem is that the actual code is so large and propertery that I
am sure no one want to really look into it.
I add few print statements in my actual code at the beginning of
rename and after. Something like:
IMPLICIT NONE
TYPE(mytype) :: a
TYPE(mytype) :: b
print *, associated(a%ptr), associated(b%ptr), size(a%ptr), size(b
%ptr)
b%ptr => a%ptr
NULLIFY(a%ptr)
%ptr)
RETURN
And I saw the second print did not give me the expected output.
Although a%ptr is not associated, its size is not zero. (I guess it is
not specified in the Fortran reference.) This is tolerable. On the
other hand, b%ptr is associated but its size is not equal to the size
of a%ptr in the first print statement. It gave me 1! If I run the code
under Debug mode, everything is just fine.
I am sorry I am not able toprovide the actual code.
Yaqi_Wang
I am also pretty frustrated because of the problem. I can not reproduce it in the testprogram too. I did the similar thing to 'rename' with 'copy(a,b) + delete(a)' in the actual code and the problem is gone. But it is really not necessary.
Actually in the real code, ptr is pointed to null() in the type definition.
The actual rename subroutine is also very simple. There is no way that I misunderstand the code.
My question is:
how possible the size of a pointer is not equal to the size of another which the pointer is just pointed to?
As I suggested in the newsgroup, the actual problem is probably not what you think it is. Rather than trying to guess as to the problem based on the symptom, I recommend that you start cutting down your real application until you get it to the minimum that shows the error. When you finally get to something which, when removed, makes the error go away, look very carefully at that thing.
I doubt that the size is the issue. You are correct that if a pointer is not associated, its size is undefined. I think it is likely you are overwriting memory somewhere.
I'll be interested to see a test case that shows the problem.
Yaqi_Wang
Thanks Steve.
The real type definition:
! Compressed Sparse Row format
TYPE CSR
INTEGER :: n ! number of rows
INTEGER :: m ! number of columns
INTEGER :: nnz ! number of non-zeros
INTEGER :: nnz_capacity ! capacity of non-zeros
INTEGER :: mcount ! memory count in bytes
REAL(RKD), DIMENSION(:), POINTER :: a =>null() ! (nnz_capacity) non-zeros
INTEGER, DIMENSION(:), POINTER :: ia =>null() ! (n+1) pointers to the beginning of each row of all non-zeros
INTEGER, DIMENSION(:), POINTER :: ja =>null() ! (nnz_capacity) column index of all non-zeros
END TYPE CSR
The real rename subroutine:
SUBROUTINE csr_rename(a, b)
IMPLICIT NONE
TYPE(CSR) :: a
TYPE(CSR) :: b
print *, a%n, a%m, a%nnz, a%nnz_capacity, associated(a%a), associated(a%ia), associated(a%ja), size(a%a), size(a%ja), size(a%ia)
print *, b%n, b%m, b%nnz, b%nnz_capacity, associated(b%a), associated(b%ia), associated(b%ja), size(b%a), size(b%ja), size(b%ia)
b%ia => a%ia
b%ja => a%ja
b%a => a%a
NULLIFY(a%ia, a%ja, a%a)
b%n = a%n
b%m = a%m
b%nnz = a%nnz
b%nnz_capacity = a%nnz_capacity
b%mcount = a%mcount
a%mcount = 0
RETURN
END SUBROUTINE csr_rename
And the output:
144 144 5216 5216 T T T 5216 5216 145
0 0 0 0 F F F 4192 4192 145
144 144 5216 5216 F F F 5216 5216 145
0 0 0 0T T T 1 1 1
The last three 1s do not make sense. The print statement happens just after the assignments. Overwriting memory does not explain this. If I use /check:all, the problem is gone.
Let me know when you have a test case I can build and run.
Yaqi_Wang
I give up to create a test case to reproduce this error. I can not get the error with the test program. Actually even in the code, this error does not happen always, but it does happen at a fixed point and the error is indeed always the wrong pointer sizes with 1 (I know this because I tried to remove few rename calls with copy+delete, which changes the place where the error occurs. it remains the same, wrong pointer sizes with 1).
So on the compiler side, can you have any thoughts on how this possibly happens with the optimization so that the range for me to find the bug is limitted? If not, I will rewrite the rename subroutine with copy+delete operations.
Are you building this from within Visual Studio? If not, add the /warn:interface option to your build. Otherwise I would check the value of the pointer at various places in the program and see where it changes unexpectedly.
I saw that Richard Maine and Jim Xia gave you some good general advice in the newsgroup.
Yaqi_Wang
Yes, I am using VS.
It changes right after the pointer assignments and nullification. Is there a way we can check the optimized code?
Sorry to sound repetitious, but if you can provide a test case we'll be glad to look at it. What is "it" that changes? I would certainly expect a pointer to change when you assign to it.
Yaqi_Wang
For the Runtime Error Checking, if I just turn 'check array and string bounds', then the error is gone.
The command line is:
/nologo /O3 /Qip /fpp /I"C:\works\tt\projects3D" /I"C:\Program Files\MPICH2\include" /gen-interfaces /Qsave /module:"Release\" /object:"Release\" /check:bounds /libs:static /threads /c /Qinline-factor=1000
Yaqi_Wang
sorry, I was replying you. I mean it changes unexpectedly. After the pointer assignment, the size of the pointer should be something other than 1. But the print statement right after the pointer assignment says no. BTW, the pointer size indeed changes after the assignment. See my posting at #3.
There may be a compiler bug, or you may have a bug in aliasing or something else. Debugging this is possible, but it is not something I can explain to you - especially without seeing the actual program.
I suggest you open an issue with Intel Premier Support and attach the actual program.
Yaqi_Wang
Thanks Steve. I know this is not good, what I can do is just describing the symptom and cannot reproducing the error with a smaller test case. But believe me it does exist.It could be totally my badsomewhere in the code. I hope somebody else may raise the similar problem in future and I can get the answer. I like Fortran and want IVF to be better. Best wishes.
