- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I am investigating a strange problem with just one of our customers on a Windows Server 2008 R2, SP1 machine.
This is an excerpt of the code:
CHARACTER*80 ICBUFF INTEGER MMBUFF PARAMETER (MMBUFF = 20) INTEGER LFBUFF(MMBUFF) REAL BFBUFF(MMBUFF) EQUIVALENCE (LFBUFF,BFBUFF) READ (ICBUFF,FMT='(BN,76X,I4)',ERR=9020) LFBUFF(1)
Crash:
Unhandled exception at 0x05C70CCE (libifcoremd.dll) in crashdump.dmp:
0xC0000005: Access violation reading location 0x45C70F80.
Version of libifcoremd.dll:
13.1 - 101 (Update A)
I could not reproduce this crash on one of our machines and it happens with just one customer only and only with this library version (newer ones not tested).
Is there any known issue, a registry setting or perhaps a problem with permissions involved?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Thank you. The address in the initial error appears to be a valid 32-bit address, ~1.1Gb. Perhaps that is within expected amount of memory range for the app to be working with.
This probably requires direct debugging to understand the root cause. Clearly something is very unique with the combination of the client’s system and your app. Another version of your product and older Intel library is not an equal comparison so that really does not offer much. The error reflects the app touching memory outside the allowable address space. That this occurred within the DLL does not directly reflect a defect with the DLL. The out-of-bound address the library accessed may have come from the app itself. That’s not meant to suggest there’s no possibility of defect in the DLL; however, it seems a defect in the DLL might show itself on other systems if that were the underlying cause.
You likely need to run a debug build of the app, maybe step through the code, with additional run-time checks enabled like /check:bounds and /traceback to get more details.
Another possibility might be to have them try a newer DLL although that may just put off the error, might avoid it even though something else might be getting unknowingly corrupted, or move it to a different location as that could change the memory footprint some. I can’t tell from the DLL’s version id exactly which older PSXE 2013 package it is from. It looks like it is within the PSXE 2013 Update 2 to Update 4 range. Older PSXE 2013 redist libraries are available from Redistributable libraries for Intel C++ and Visual Fortran Composer XE 2013 for Windows. Perhaps one could try only a newer version of the libifcore Intel DLL from a release newer than the version of PSXE 2013 used to build the app.
Finally, I don’t know whether the Doctor’s earlier article, Don't Touch Me There - What error 157 (Access Violation) is trying to tell you would offer other ideas/insight.
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I’m unsure what is at play.
Is the app build IA-32 or Intel 64?
Are you saying it does not fail on your system with the same version of the library?
Have you tried setting Fortran > Run-Time > Generate Traceback Information to Yes and re-running to get some additional call stack details.
Does the code excerpt represent the point where you know the failure occurs?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
IA-32
It works on many machines with different operating systems and this is the first report that it does not work. Another version of our product with an older library version works on that machine.
Unfortunately - this is on a clients machine, but I got the following Stacktrace with CrashReport:
(libifcoremd.dll Dateiversion is 13.1.101.101)
> libifcoremd.dll!05db0cce() Unknown [Frames below may be incorrect and/or missing, no symbols loaded for libifcoremd.dll] libifcoremd.dll!05d8adb4() Unknown ntdll.dll!7759f915() Unknown ntdll.dll!7759f8e1() Unknown libifcoremd.dll!05d2b955() Unknown libifcoremd.dll!05d48531() Unknown libifcoremd.dll!05d89167() Unknown
Part of the disassembly:
05DB0C5C sub ecx,80h 05DB0C62 movdqu xmm0,xmmword ptr [esi-80h] 05DB0C67 movdqu xmm1,xmmword ptr [esi-70h] 05DB0C6C movdqu xmm2,xmmword ptr [esi-60h] 05DB0C71 movdqu xmm3,xmmword ptr [esi-50h] 05DB0C76 movdqu xmm4,xmmword ptr [esi-40h] 05DB0C7B movdqu xmm5,xmmword ptr [esi-30h] 05DB0C80 movdqu xmm6,xmmword ptr [esi-20h] 05DB0C85 movdqu xmm7,xmmword ptr [esi-10h] 05DB0C8A movntdq xmmword ptr [edx-80h],xmm0 05DB0C8F movntdq xmmword ptr [edx-70h],xmm1 05DB0C94 movntdq xmmword ptr [edx-60h],xmm2 05DB0C99 movntdq xmmword ptr [edx-50h],xmm3 05DB0C9E movntdq xmmword ptr [edx-40h],xmm4 05DB0CA3 movntdq xmmword ptr [edx-30h],xmm5 05DB0CA8 movntdq xmmword ptr [edx-20h],xmm6 05DB0CAD movntdq xmmword ptr [edx-10h],xmm7 05DB0CB2 cmp ecx,80h 05DB0CB8 jge 05DB0C50 05DB0CBA mov eax,ecx 05DB0CBC shr eax,4 05DB0CBF shl eax,4 05DB0CC2 add edx,eax 05DB0CC4 add esi,eax 05DB0CC6 sub ecx,eax 05DB0CC8 shr eax,4 05DB0CCB sfence 05DB0CCE jmp dword ptr [eax*4+5DB0F90h] <----- code pointer 05DB0CD5 cmp ecx,80h 05DB0CDB jge 05DB0CE0 05DB0CDD jmp 05DB0D48 05DB0CDF nop 05DB0CE0 sub ecx,80h 05DB0CE6 movdqa xmm0,xmmword ptr [esi] 05DB0CEA movdqa xmm1,xmmword ptr [esi+10h] 05DB0CEF movdqa xmmword ptr [edx],xmm0 05DB0CF3 movdqa xmmword ptr [edx+10h],xmm1 05DB0CF8 movdqa xmm2,xmmword ptr [esi+20h] 05DB0CFD movdqa xmm3,xmmword ptr [esi+30h] 05DB0D02 movdqa xmmword ptr [edx+20h],xmm2 05DB0D07 movdqa xmmword ptr [edx+30h],xmm3 05DB0D0C movdqa xmm4,xmmword ptr [esi+40h]
Thanks for looking into this.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Update:
I could not find the cause, but I suspect some interference with some other software. Our customer is now testing other options, so we won't invest any more time in that. Hopefully, no one else will have that problem.
Thanks for your suggestions.
Lothar
