Are IF8-libs in IF9 compatibel ?
hansr
Have I to compile all my old IF8-libs to use with IF9-programs?
(I'm seeking the cause that some of my programs don't run since IF9.1.029 with QZero)
Yes, they're compatible. Of course, recompiling if you can is a good idea as you'll get the advantage of the newer compiler for all your code.
Note that this does not work the other way - you can't take an IF9-compiled lib and use it with IF8.
