29235 Discussions
Array size limits on Max OS X with IFORT 10.1.007 when using atmospheric model?
steven1
I hope somebody can help me with an issue I have -- I'm trying to run the global atmospheric chemical transport model GEOS-CHEM on a Mac Pro (OS X 10.5).
It seems that when I run the code, where there are large arrays the code compiles and initially starts running OK, but then when the arrays are accessed or the subroutine which declares them is entered, a segmentation fault occurs.
I checked this is the case by reducing the array size for some parts of the code where I could get away with this. I need REAL*8 arrays of just over 4.5 million in size.
The simulations work on Linux.
If anyone has a suggestion (perhaps a compiler flag?) on how I can overcome this It'd be great.
Steven
TimP
Does it set the 64-bit integer type for indexing these arrays on both linux and MacOS?
steven1
Thank you for your message.
I'm afraid I don't understand -- I can only successfully compile for 32 bit though?
But I see where you're going, a 32 bit integer can only index a bit under 4.5 million right?
Steven
TimP
32-bit mode limits arrays to 2GB. Maybe that is plenty in your case. You must also watch for stack overflow, if local arrays are allocated on stack, which happens by default when using f90 array operations. If the stack size defaults are different between MacOS and linux, or you increased stack size for linux, or you are using different compilers, it could explain a difference.
Try -heap-arrays
