29285 Discussions
Aspen User Kinetic Subroutine with Intel fortran compiler - Fortran divide by zero error
ayyappan__lakshmanan
Hello Everyone ,
I am currently working on implementing the kinetic reactions in Aspen plus for reactive distillation through user kinetic subroutine with Fortran Compiler 2017 and VS 14/2015 . After writing the code , compilation and linking the subroutine with ASPLINK procedure . During running the simulations in Aspen , I am encountering Severe error  - Fortran divide by zero encountered. Severe error - Fortran invalid operations encountered . I am doubtful if this is due to error in linking of the subroutine or error due to parameters not passing from Aspen to Fortran (due to coding errors)  .
Please can some one help me with this . Looking forward to hear from you.
With Regards,
Lakshmanan
Steve_Lionel
Nobody here would be able to help with this given that we have no idea what your subroutine is doing. You will have to debug it - you can use the debugger or can add print statements to examine intermediate computations. Typically a zerodivide would result in a NaN - if you have compiled the Fortran code with the /fpe0 option, it might get a zerodivide on division by zero, But either way, division by zero is usually not intentional.
JohnNichols
Valued Contributor III
This is a common feature in developing new code -- the print statements are usually the fastest way
Trust me I do it a lot.
