Assign Parameter to Parameter with negation - Missing error message? (+warning #5436)
Wolf_W_
i tried to put some test cases into a loop. I wanted to collect some user-defined-type constants in an array. When i tried to use a negation i got some garbage numbers. I assume, that the use of that negation wasn't legal in the first place, but i think the compiler is missing some error-messages here.
It gives a warning message:
udt_parameter_array.f90(38): warning #5436: Overlapping storage initializations encountered with SCALAR_N_A
The reproducer:
module M_TEST
  implicit none
  public
  type t_test_a
    real :: v(2)
    contains
    ! Without the type-bound procedure, there is no garbage, but negation does not work
    procedure :: negate
    ! Without the operator binding, there is still garbage produced
!    generic :: operator(-) => negate
  end type
  type t_test_b
    real :: v(2)
  end type
  type(t_test_a), parameter :: vx_a = t_test_a([1.0,0.0])
  type(t_test_a), parameter :: vy_a = t_test_a([0.0,1.0])
  type(t_test_a), parameter :: array_a(4) = [vx_a, vy_a,  -vx_a, -vy_a] ! Here should be an error message(?)
  type(t_test_b), parameter :: vx_b = t_test_b([1.0,0.0])
  type(t_test_b), parameter :: vy_b = t_test_b([0.0,1.0])
  type(t_test_b), parameter :: array_b(4) = [vx_b, vy_b,  -vx_b, -vy_b] ! Here should be an error message(?)
  contains
  function negate(this)
    class(t_test_a), intent(in   ) :: this
    type(t_test_a) :: negate
    negate%v = -this%v
  end function
end module
program udt_parameter_array
  use M_TEST
  implicit none
  type(t_test_a), parameter :: scalar_p_a =  vx_a
  type(t_test_a), parameter :: scalar_n_a = -vx_a ! Here should be an error message(?)
  type(t_test_b), parameter :: scalar_p_b =  vx_b
  type(t_test_b), parameter :: scalar_n_b = -vx_b ! Here should be an error message(?)
  write(*,'(A12, 3x, *(G23.15,2x))') 'array_a(1)', array_a(1)
  write(*,'(A12, 3x, *(G23.15,2x))') 'array_a(2)', array_a(2)
  write(*,'(A12, 3x, *(G23.15,2x))') 'array_a(3)', array_a(3)
  write(*,'(A12, 3x, *(G23.15,2x))') 'array_a(4)', array_a(4)
  write(*,'(A12, 3x, *(G23.15,2x))') 'scalar_p_a', scalar_p_a
  write(*,'(A12, 3x, *(G23.15,2x))') 'scalar_n_a', scalar_n_a
  write(*,*)
  write(*,'(A12, 3x, *(G23.15,2x))') 'array_b(1)', array_b(1)
  write(*,'(A12, 3x, *(G23.15,2x))') 'array_b(2)', array_b(2)
  write(*,'(A12, 3x, *(G23.15,2x))') 'array_b(3)', array_b(3)
  write(*,'(A12, 3x, *(G23.15,2x))') 'array_b(4)', array_b(4)
  write(*,'(A12, 3x, *(G23.15,2x))') 'scalar_p_b', scalar_p_b
  write(*,'(A12, 3x, *(G23.15,2x))') 'scalar_n_b', scalar_n_b
end program
Output on my PC:
  array_a(1)      0.00000000000000        0.227795078360642E-40
  array_a(2)      0.00000000000000         0.00000000000000
  array_a(3)     0.114615003994055E-39     0.00000000000000
  array_a(4)     0.918354961579912E-40     0.00000000000000
  scalar_p_a      1.00000000000000         0.00000000000000
  scalar_n_a     0.358732406867153E-42     0.00000000000000
  array_b(1)      0.00000000000000        0.882818032524635E-43
  array_b(2)      0.00000000000000         0.00000000000000
  array_b(3)     0.882818032524635E-43     0.00000000000000
  array_b(4)      0.00000000000000         0.00000000000000
  scalar_p_b      0.00000000000000        0.882818032524635E-43
  scalar_n_b      0.00000000000000         0.00000000000000
It works without the negations in the assignment or when type A has no type bound procedure.
OS: Windows 7
Compiler: Ifort 16.3.207
Options: /Od /warn:all /stand:f08 /C
Greetings,
Wolf
Kevin_D_Intel
Thank you for reporting this. It appears the compiler is perhaps missing flagging an error here. I tried an even simpler case that triggered an internal compiler error. I escalated your case to Development.
(Internal tracking id: DPD200413583)
FortranFan
 It appears the compiler is perhaps missing flagging an error here.. ..
@Kevin D.,
What error you think the compiler is missing out on?  Upon first glance, the code in the original post looks Ok to me.  The use of operator(-) also appears legit.  Now I may be wrong, so would like to understand better.
I think I have seen this before. if anything, I think the Intel Fortran compiler has a couple of issues: the correct use of the derived type with an operator in an array initialization expression and an ICE when such an initialization is made use of with a named constant (meaning with PARAMETERs).  I would sincerely request you take the code in the original post and slice and dice it up into even smaller reproducers of the above couple of issues and submit to your development.  For example, try the code below with gfortran and Intel Fortran and see what you get:
module M_TEST
   implicit none
   public
   type t_test_a
      real :: v(2)
   contains
      procedure, pass(this) :: negate
   end type
   type(t_test_a), parameter :: vx_a = t_test_a( [1.0, 0.0] )
contains
      class(t_test_a), intent(in) :: this
      negate%v = -this%v
   end function negate
end module
   use M_TEST, only : t_test_a, vx_a
   implicit none
   type(t_test_a) :: foo(1)
   foo = [ -vx_a ]
   write(*,'(A12, 3x, *(G23.15,2x))') 'foo = ', foo(1)
end program
IanH
Initializers in type declaration statements must be constant expressions.  A reference to a user defined operation is not permitted in a constant expression.
