BINARY NUMBER and the DIGITS
JohnNichols
소중한 기여자 III
3,561 조회수
If I have a binary number 101010 - as a decimal number 42 - is there an easy FORTRAN function to convert to a binary number and then determine the order of 1 and 0's --
John
0 포인트
5 응답
Les_Neilson
소중한 기여자 II
3,561 조회수
John
I'm not sure exactly what you mean. All numbers are stored internally as binary. You can use internal write to put the binary format of a number into a character string which you can print or process somehow.
If you want to test whether a particular bit is set or not you should look up BTEST in the help. The help also points to functions that allow the user to clear, set, or swap a particular bit.
Les
0 포인트
andrew_4619
명예로운 기여자 III
3,562 조회수
for example
integer(4)      :: l1
character(32) :: gchar
write(gchar,'(B32.32)') l1
which would set the string to '00000000000000000000000000010001' if L1 was 17
0 포인트
Steven_L_Intel1
3,562 조회수
There's also the intrinsic function POPCNT which will tell you the number of 1 bits in a value. (see also LEADZ and TRAILZ.)
0 포인트
JohnNichols
소중한 기여자 III
3,562 조회수
program Console1
    implicit none
    character(6) :: gchar
    character :: a
    integer :: i = 2
    integer :: pos
    logical :: bool
    integer(4)      :: l1
    l1 = 17
    write(gchar,'(B6.6)') l1
    do pos=6,0,-1
        bool = btest(i, pos)
        if(bool .eq. .TRUE.) then
            print *, pos, 1
        else
            print *, pos, 0
        endif
    end do
    end program Console1
Explanation:
In structures a restraint point can have 6 degrees of - each freedom is either set or released ie 1 or 0 is the usual code.  One ends up with a file with every joint having 6 integers usually stored as integer a(6) - one ends up trying to remember binary codes.  Now AUTODESK has a neat function in AutoCAD for setting some switches - you pick a decimal - 1, 2, 4, 8 and it sets the switch - I was wondering as I developed Borr - see the long discussion top that now runs to 30 pages if printed - I did - if I could use a integer code 0- 63 to cover all the restraint options.  The answer is a resounding yes, but one needs a large case statement to step through the combinations - or look up the binary equivalent of the integer directly.  So now I can input a full restraint as a 63 and a free as 0, lot less typing and less likely to miss one.  The other common one is 111000 or 56.  I was not aware of the BTEST function and my INTEL install on the home computer does not give me a nice help system - a WINDOWS 10 upgrade appears to have played with it - no search no nothing,  so I asked.
This code is great - thanks
John
0 포인트
jimdempseyatthecove
명예로운 기여자 III
3,562 조회수
By the use of a binary bit field, you imply that multiple bits can be set. Therefor you would not have a select case, but rather you would have a filter.
if(bitest(Mask, 0)) call DoWork0()
if(bitest(Mask, 1)) call DoWork1()
However note you can create an array of function pointers, and note, if each DoWork can run independently, you could parallelize the code
!$omp parallel do schedule(dynamic, 1)
do i=1,64
  if(btest(Mask, i)) FunctionPointerArray(i)%DoWork()
end do
Jim Dempsey
0 포인트
응답
