- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Here is a code that creates Barabasi Albert model for any number of nodes for any number of degrees, the code fully compiles with g++ but shows error while compiling with icpc(intel c++ compiler). I am attaching the code with the error report with this post.
#include<bits/stdc++.h> using namespace std; int EMPTY = 0; int connectionNumber = 0; vector<unsigned> network[3000001]; //seed for the network to grow void seed(int netmap1[],int netmap2[],int N) { connectionNumber = 0; for(unsigned i=1;i<=N;i++) { for(unsigned j=1;j<=N;j++) { if(i!=j) { network.push_back(j); } if(j>i) { connectionNumber++; netmap1[connectionNumber]=i; netmap2[connectionNumber]=j; } } } } //actual node building on the algorithm of barabasi albert model //stores the connection of each node in netmap1 and netmap2 void BA(int netmap1[],int netmap2[],int N,int seedNumber, int m) { srand(time(NULL)); int concheck=0; int a= {}; int countm=0; double totalpk,pk; for(int i = seedNumber+1;i<=N;i++) { countm=0; cout<<"connection given to : "<<i<<endl; totalpk = 0.0; for(int n=0;n<m;n++) { a =0; } for(int l=1;l<i;l++) { totalpk += network .size(); } for(int j = 1; ; j++) { concheck = 0; double u = (double)rand()/RAND_MAX; pk = 0.0; for(int k=1;k<i;k++) { if(concheck==1) break; pk += (double)(network .size())/totalpk; if(u<pk) { concheck = 0; for(int n=0;n<m;n++) { if(a ==k) { concheck = 1; } } if(concheck==0) { a[countm]=k; countm++; network .push_back(i); network.push_back(k); connectionNumber++; netmap1[connectionNumber]=k; netmap2[connectionNumber]=i; totalpk += 2; break; } else continue; } } if(countm==m) { break; } } } } int findroot(int ptr[],int i) { if(ptr<0) return i; return ptr=findroot(ptr,ptr); } //does explosive percolation with newman-ziff algorithm void explosivepercolation(int netmap1[],int netmap2[],int vertices, int run, int filenum, int m) { srand(time(NULL)); int A,B,C; A = vertices; B = run; C = filenum; string filename1; filename1 = "maxclus_"; string filename2; filename2 = "delmx_"; string filename3; filename3 = "entropy_"; filename1 = filename1+to_string(A)+"node_"+to_string(m)+"M_"+to_string(B)+"ens_"+to_string(C)+".dat"; filename2 = filename2+to_string(vertices)+"node_"+to_string(m)+"M_"+to_string(run)+"ens"+to_string(filenum)+".dat"; filename3 = filename3+to_string(vertices)+"node_"+to_string(m)+"M_"+to_string(run)+"ens"+to_string(filenum)+".dat"; ofstream fout1,fout2,fout3; int* random = NULL; random = new int[connectionNumber+1]; double* maxclus = NULL; maxclus = new double[connectionNumber+1]; double* delmx = NULL; delmx = new double[connectionNumber+1]; double* entropycalc = NULL; entropycalc = new double[connectionNumber+1]; for(int i=0;i<=connectionNumber;i++) { maxclus=0; delmx=0; entropycalc=0; } for(int i=0;i<=connectionNumber;i++) { random = i; } int* ptr = new int[vertices+1]; for(int i=0;i<vertices+1;i++) ptr=0; //here it starts percolating for number of runs to take ensemble average for(int rx=1;rx<=run;rx++) { cout<<"run commencing : "<<rx<<endl; for(int i=0;i<vertices+1;i++) ptr=0; int index=0,big=0,bigtemp=0,jump=0,en1=0,en2=0; int node1=0,node2=0,node3=0,node4=0,nodeA=0,nodeB=0; int clus1=0,clus2=0,clus3=0,clus4=0; long double entropy = log(vertices); random_shuffle(&random[1],&random[connectionNumber]); for(int i=0;i<=vertices;i++) ptr = EMPTY; for(int i=1;i<=connectionNumber;i++) { if(i!=connectionNumber) { node1 = netmap1[random]; node2 = netmap2[random]; node3 = netmap1[random[i+1]]; node4 = netmap2[random[i+1]]; if(ptr[node1]==EMPTY) clus1 = 1; else { int x = findroot(ptr,node1); clus1 = -ptr ; } if(ptr[node2]==EMPTY) clus2 = 1; else { int b = findroot(ptr,node2); clus2 = -ptr; } if(ptr[node3]==EMPTY) clus3 = 1; else { int c = findroot(ptr,node3); clus3 = -ptr ; } if(ptr[node4]==EMPTY) clus4 = 1; else { int d = findroot(ptr,node4); clus4 = -ptr ; } if(clus1*clus2<clus3*clus4) { nodeA = node1; nodeB = node2; int N1=connectionNumber; int M1=i+1; int u = M1 + rand()/(RAND_MAX/(N1-M1+1) + 1); int temp = random; random = random[i+1]; random[i+1] = temp; } else { nodeA = node3; nodeB = node4; int temp = random[i+1]; random[i+1] = random; random = temp; int N1=connectionNumber; int M1=i+1; int u = M1 + rand()/(RAND_MAX/(N1-M1+1) + 1); temp = random; random = random[i+1]; random[i+1] = temp; } } else { nodeA = netmap1[random]; nodeB = netmap2[random]; } if(ptr[nodeA]==EMPTY && ptr[nodeB]==EMPTY) { en1=1; en2=1; ptr[nodeA] = -2; ptr[nodeB] = nodeA; index = nodeA; entropy = (long double)(entropy-(-2.0/vertices*log(1.0/vertices))+(-2.0/vertices*log(2.0/vertices))); if(entropy<0) entropy = 0; } else if(ptr[nodeA]==EMPTY && ptr[nodeB]!=EMPTY) { en1=1; int e = findroot(ptr,nodeB); en2 = -(ptr ); ptr[nodeA] = e; ptr += -1; index = e; entropy = entropy-(-(double)1.0/vertices*log(1.0/(double)vertices))-(-(double)en2/vertices*log((double)en2/vertices))+(-( double)(-ptr[index])/vertices*log((-ptr[index])/(double)vertices)); if(entropy<0) entropy = 0; } else if(ptr[nodeA]!=EMPTY && ptr[nodeB]==EMPTY) { en2 = 1; int f = findroot(ptr,nodeA); en1 = -(ptr ); ptr[nodeB] = f; ptr += -1; index = f; entropy = entropy-(-(double)1.0/(long double)vertices*log(1.0/(long double)vertices))-(-(double)en1/(long double)vertices*log((long double)en1/vertices))+(-(long double)(-ptr[index])/vertices*log((-ptr[index])/(long double)vertices)); if(entropy<0) entropy = 0; } else if(ptr[nodeA]!=EMPTY && ptr[nodeB]!=EMPTY) { int g,h; g = findroot(ptr,nodeA); en1 = -(ptr ); h = findroot(ptr,nodeB); en2 = -(ptr ); if(g!=h) { if(ptr <ptr ) { ptr += ptr ; ptr = g; index = g; } else { ptr += ptr ; ptr = h; index = h; } entropy = entropy-(-(long double)en1/(long double)vertices*log((long double)en1/(long double)vertices))-(-(long double)en2/vertices*log((long double)en2/(long double)vertices))+(-(long double)(-ptr[index])/vertices*log((long double)(-ptr[index])/(long double)vertices)); if(entropy<0) entropy = 0; } else { jump=big-bigtemp; maxclus += big; delmx += jump; if(entropy<0) entropy = 0; entropycalc += entropy; bigtemp = big; continue; } } if(-ptr[index]>big) big = -ptr[index]; jump = big - bigtemp; maxclus += big; delmx += jump; entropycalc += entropy; bigtemp = big; } } fout1.open(filename1.c_str()); fout2.open(filename2.c_str()); fout3.open(filename3.c_str()); //saves the result of maxcluster, jump and entropy calculation to file for(int i=1;i<=connectionNumber;i++) { fout1<<(double)i/connectionNumber<<'\t'<<(double)maxclus/vertices/run<<endl; fout2<<(double)i/connectionNumber<<'\t'<<(double)delmx/run<<endl; fout3<<(double)i/connectionNumber<<'\t'<<(double)entropycalc/run<<endl; } fout1.close(); fout2.close(); fout3.close(); delete[] random; random = NULL; delete[] maxclus; maxclus = NULL; delete[] delmx; delmx = NULL; delete[] entropycalc; entropycalc = NULL; } int main() { int a,b,c,d,e,f; cout<<"enter seed size: "; cin>>a; cout<<endl; cout<<"enter vertice number: "; cin>>b; cout<<endl; cout<<"order number: "; cin>>c; cout<<endl; cout<<"enter ensemble number: "; cin>>d; cout<<endl; cout<<"enter filenumber: "; cin>>e; cout<<endl; int con = 0; for(int i=1;i<a;i++) { con = con + i; } con = con + (b-a)*c; int* ntmp1 = new int[con+1]; int* ntmp2 = new int[con+1]; for(int i=1;i<=con;i++) { ntmp1 = 0; ntmp2 = 0; } seed(ntmp1,ntmp2,a); BA(ntmp1,ntmp2,b,a,c); explosivepercolation(ntmp1,ntmp2,b,d,e,c); delete [] ntmp1; ntmp1 = NULL; delete [] ntmp2; ntmp2 = NULL; return 0; }
now the error it shows on icpc is
if any kind soul know how to fix this, please help me out.
링크가 복사됨
1 응답
