29285 Discussions
Barabasi Albert Network Generator and Percolator compiles with g++ but doesnt on icpc with strange error
digonto_i_
Here is a code that creates Barabasi Albert model for any number of nodes for any number of degrees, the code fully compiles with g++ but shows error while compiling with icpc(intel c++ compiler). I am attaching the code with the error report with this post.
    #include<bits/stdc++.h>
    using namespace std;
    int EMPTY = 0;
    int connectionNumber = 0;
    vector<unsigned> network[3000001];
    //seed for the network to grow
    void seed(int netmap1[],int netmap2[],int N)
    	for(unsigned i=1;i<=N;i++)
    		for(unsigned j=1;j<=N;j++)
    			if(i!=j)
    				network.push_back(j);
    			if(j>i)
    				connectionNumber++;
    				netmap1[connectionNumber]=i;
    				netmap2[connectionNumber]=j;
    //actual node building on the algorithm of barabasi albert model
    //stores the connection of each node in netmap1 and netmap2
    void BA(int netmap1[],int netmap2[],int N,int seedNumber, int m)
    	srand(time(NULL));
    	int concheck=0;
    	int a = {};
    	int countm=0;
    	double totalpk,pk;
    	for(int i = seedNumber+1;i<=N;i++)
    		countm=0;
    		cout<<"connection given to : "<<i<<endl;
    		totalpk = 0.0;
    		for(int n=0;n<m;n++)
    				a=0;
    		for(int l=1;l<i;l++)
    			totalpk += network.size();
    		for(int j = 1; ; j++)
    			concheck = 0;
    			double u = (double)rand()/RAND_MAX;
    			pk = 0.0;
    			for(int k=1;k<i;k++)
    				if(concheck==1) break;
    				pk += (double)(network.size())/totalpk;
    				if(u<pk)
    					concheck = 0;
    						if(a==k)
    							concheck = 1;
    					if(concheck==0)
    						a[countm]=k;
    						countm++;
    						network.push_back(i);
    						network.push_back(k);
    						connectionNumber++;
    						netmap1[connectionNumber]=k;
    						netmap2[connectionNumber]=i;
    						totalpk += 2;
    						break;
    					else continue;
    			if(countm==m)
    				break;
    int findroot(int ptr[],int i)
    	if(ptr<0) return i;
    	return ptr=findroot(ptr,ptr);
    //does explosive percolation with newman-ziff algorithm
    void explosivepercolation(int netmap1[],int netmap2[],int vertices, int run, int filenum, int m)
    	srand(time(NULL));
    	int A,B,C;
    	A = vertices;
    	B = run;
    	C = filenum;
    	string filename1;
    	filename1 = "maxclus_";
    	string filename2;
    	filename2 = "delmx_";
    	string filename3;
    	filename3 = "entropy_";
    	filename1 = filename1+to_string(A)+"node_"+to_string(m)+"M_"+to_string(B)+"ens_"+to_string(C)+".dat";
    	filename2 = filename2+to_string(vertices)+"node_"+to_string(m)+"M_"+to_string(run)+"ens"+to_string(filenum)+".dat";
    	filename3 = filename3+to_string(vertices)+"node_"+to_string(m)+"M_"+to_string(run)+"ens"+to_string(filenum)+".dat";
    	ofstream fout1,fout2,fout3;
    	int* random = NULL;
    	random = new int[connectionNumber+1];
    	double* maxclus = NULL;
    	maxclus = new double[connectionNumber+1];
    	double* delmx = NULL;
    	delmx = new double[connectionNumber+1];
    	double* entropycalc = NULL;
    	entropycalc = new double[connectionNumber+1];
    	for(int i=0;i<=connectionNumber;i++)
    		maxclus=0;
    		delmx=0;
    		entropycalc=0;
    		random = i;
    	int* ptr = new int[vertices+1];
    	for(int i=0;i<vertices+1;i++) ptr=0;
    	//here it starts percolating for number of runs to take ensemble average
    	for(int rx=1;rx<=run;rx++)
    		cout<<"run commencing : "<<rx<<endl;
    		int index=0,big=0,bigtemp=0,jump=0,en1=0,en2=0;
    		int node1=0,node2=0,node3=0,node4=0,nodeA=0,nodeB=0;
    		int clus1=0,clus2=0,clus3=0,clus4=0;
    		long double entropy = log(vertices);
    		random_shuffle(&random[1],&random[connectionNumber]);
    		for(int i=0;i<=vertices;i++) ptr = EMPTY;
    		for(int i=1;i<=connectionNumber;i++)
    			if(i!=connectionNumber)
    				node1 = netmap1[random];
    				node2 = netmap2[random];
    				node3 = netmap1[random[i+1]];
    				node4 = netmap2[random[i+1]];
    				if(ptr[node1]==EMPTY) clus1 = 1;
    				else
    					int x = findroot(ptr,node1);
    					clus1 = -ptr;
    				if(ptr[node2]==EMPTY) clus2 = 1;
    				else
    					int b = findroot(ptr,node2);
    					clus2 = -ptr;
    				if(ptr[node3]==EMPTY) clus3 = 1;
    				else
    					int c = findroot(ptr,node3);
    					clus3 = -ptr;
    				if(ptr[node4]==EMPTY) clus4 = 1;
    				else
    					int d = findroot(ptr,node4);
    					clus4 = -ptr;
    				if(clus1*clus2<clus3*clus4)
    					nodeA = node1;
    					nodeB = node2;
    					int N1=connectionNumber;
    					int M1=i+1;
    					int u = M1 + rand()/(RAND_MAX/(N1-M1+1) + 1);
    					int temp = random;
    					random = random[i+1];
    					random[i+1] = temp;
    				else
    					nodeA = node3;
    					nodeB = node4;
    					int temp = random[i+1];
    					random[i+1] = random;
    					random = temp;
    					int M1=i+1;
    					temp = random;
    					random[i+1] = temp;
    			else
    				nodeA = netmap1[random];
    				nodeB = netmap2[random];
    			if(ptr[nodeA]==EMPTY && ptr[nodeB]==EMPTY)
    			en1=1;
    			en2=1;
    			ptr[nodeA] = -2;
    			ptr[nodeB] = nodeA;
    			index = nodeA;
    			entropy = (long double)(entropy-(-2.0/vertices*log(1.0/vertices))+(-2.0/vertices*log(2.0/vertices)));
    			if(entropy<0) entropy = 0;
    			else if(ptr[nodeA]==EMPTY && ptr[nodeB]!=EMPTY)
    			en1=1;
    			int e = findroot(ptr,nodeB);
    			en2 = -(ptr);
    			ptr[nodeA] = e;
    			ptr += -1;
    			index = e;
    			entropy = entropy-(-(double)1.0/vertices*log(1.0/(double)vertices))-(-(double)en2/vertices*log((double)en2/vertices))+(-( double)(-ptr[index])/vertices*log((-ptr[index])/(double)vertices));
    			else if(ptr[nodeA]!=EMPTY && ptr[nodeB]==EMPTY)
    			en2 = 1;
    			int f = findroot(ptr,nodeA);
    			en1 = -(ptr);
    			ptr[nodeB] = f;
    			ptr += -1;
    			index = f;
    			entropy = entropy-(-(double)1.0/(long double)vertices*log(1.0/(long double)vertices))-(-(double)en1/(long double)vertices*log((long double)en1/vertices))+(-(long double)(-ptr[index])/vertices*log((-ptr[index])/(long double)vertices));
    			else if(ptr[nodeA]!=EMPTY && ptr[nodeB]!=EMPTY)
    				int g,h;
    				g = findroot(ptr,nodeA);
    				en1 = -(ptr);
    				h = findroot(ptr,nodeB);
    				en2 = -(ptr);
    				if(g!=h)
    					if(ptr<ptr)
    						ptr += ptr;
    						ptr = g;
    						index = g;
    					else
    						ptr += ptr;
    						ptr = h;
    						index = h;
    					entropy = entropy-(-(long double)en1/(long double)vertices*log((long double)en1/(long double)vertices))-(-(long double)en2/vertices*log((long double)en2/(long double)vertices))+(-(long double)(-ptr[index])/vertices*log((long double)(-ptr[index])/(long double)vertices));
    				else
    					jump=big-bigtemp;
    					maxclus += big;
    					delmx += jump;
    					entropycalc += entropy;
    					bigtemp = big;
    					continue;
    			if(-ptr[index]>big) big = -ptr[index];
    			jump = big - bigtemp;
    			maxclus += big;
    			delmx += jump;
    			bigtemp = big;
    	fout1.open(filename1.c_str());
    	fout2.open(filename2.c_str());
    	fout3.open(filename3.c_str());
    	//saves the result of maxcluster, jump and entropy calculation to file
    		fout1<<(double)i/connectionNumber<<'\t'<<(double)maxclus/vertices/run<<endl;
    		fout2<<(double)i/connectionNumber<<'\t'<<(double)delmx/run<<endl;
    		fout3<<(double)i/connectionNumber<<'\t'<<(double)entropycalc/run<<endl;
    	fout1.close();
    	fout2.close();
    	fout3.close();
    	delete[] random;
    	random = NULL;
    	delete[] maxclus;
    	maxclus = NULL;
    	delete[] delmx;
    	delmx = NULL;
    	delete[] entropycalc;
    	entropycalc = NULL;
    int main()
    	int a,b,c,d,e,f;
    	cout<<"enter seed size: ";
    	cin>>a;
    	cout<<endl;
    	cout<<"enter vertice number: ";
    	cin>>b;
    	cout<<endl;
    	cout<<"order number: ";
    	cin>>c;
    	cout<<endl;
    	cout<<"enter ensemble number: ";
    	cin>>d;
    	cout<<endl;
    	cout<<"enter filenumber: ";
    	cin>>e;
    	cout<<endl;
    	int con = 0;
    	for(int i=1;i<a;i++)
    		con = con + i;
    	con = con + (b-a)*c;
    	int* ntmp1 = new int[con+1];
    	int* ntmp2 = new int[con+1];
    	for(int i=1;i<=con;i++)
    		ntmp1 = 0;
    		ntmp2 = 0;
    	seed(ntmp1,ntmp2,a);
    	BA(ntmp1,ntmp2,b,a,c);
    	explosivepercolation(ntmp1,ntmp2,b,d,e,c);
    	delete [] ntmp1;
    	ntmp1 = NULL;
    	delete [] ntmp2;
    	ntmp2 = NULL;
    	return 0;
now the error it shows on icpc is
if any kind soul know how to fix this, please help me out.
mecej4
This is the Intel Fortran for Linux/Mac forum, and if there is a connection of your post to Fortran, I don't see it! There is a separate forum for the Intel C/C++ compiler.
