hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
28990 討論
Binding label restriction for submodule procedures
jwmwalrus
新貢獻者 I
699 檢視
Hi.
The following code
module mod1
    use ISO_C_BINDING
    implicit none
    private
    interface
        module subroutine dummy()
        end subroutine
    end interface
end module
submodule (mod1) sm_callback
    implicit none
contains
    module procedure dummy
    end procedure
    function callback(arg) bind(C) result(res)
        type(C_PTR) :: res
        type(C_PTR), value :: arg
        res = C_NULL_PTR
    end function
end submodule
Fails to compile with
$ ifx -V -c /media/vmshare/submod-callback.f90
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2025.0.1 Build 20241113
Copyright (C) 1985-2024 Intel Corporation. All rights reserved.
 Intel(R) Fortran 25.0-1205.1
/media/vmshare/submod-callback.f90(17): error #6117: A module procedure in a submodule that is not a separate module procedure cannot have a binding label.
compilation aborted for /media/vmshare/submod-callback.f90 (code 1)
I know that the solutions is to just have an interface block for the "callback" function in the parent module, but why is that necessary?
Btw, gfortran 14 compiles the code without issue.
0 積分
1 解決方案
Steve_Lionel
榮譽貢獻者 III
548 檢視
The only thing that occurs to me, is that there's probably another constraint that guarantees that the procedure name is not mangled only if its interface is declared in the parent module.
I think this is it.
在原始文章中檢視解決方案
7 回應
andrew_4619
榮譽貢獻者 III
670 檢視
Well without the interface it has no external visibility and the whole point of bind(C) is to allow it to be called from C so to me that is a sound call by the compiler. As to what the standard chapter and verse says I have not looked.....
jwmwalrus
新貢獻者 I
636 檢視
Isn't the visibility really a thing of the linker? Having the interface block doesn't seem to add much.
I have code that does this
module mod1
    use ISO_C_BINDING
    implicit none
    private
    interface
        end subroutine
    end interface
end module
    implicit none
contains
        ! invoke C function here, passing callback as an arg.
    contains
            type(C_PTR) :: res
            res = C_NULL_PTR
        end function
    end procedure
end submodule
That is, the callback being passed is a contained procedure, and it works just fine. It was only when I tried to re-use that same callback from multiple places in the submodule, that the error was thrown.
Steve_Lionel
榮譽貢獻者 III
629 檢視
C1807 A procedure defined in a submodule shall not have a binding label unless its interface is declared in the ancestor module.
NAG Fortran also doesn't like your code either. I played with this for a bit but couldn't figure out how to satisfy the standard - perhaps I'm just tired.
jwmwalrus
新貢獻者 I
622 檢視
Thanks for the pointer to the standard.
I still fail to see how passing a contained procedure is okay, but a non-contained one requires an interface in the parent module.
Do you mind expanding on the reasoning behind that constraint?
andrew_4619
榮譽貢獻者 III
581 檢視
It isn't OK in my opinion. As to "Isn't the visibility really a thing of the linker?" , well no, I want procedures in a sub-module to have no external visibility, they are private and if they were not so it invalidates the purpose of a sub-module which is to separate interface and implementation to minimise build cascades.
jwmwalrus
新貢獻者 I
569 檢視
We're talking about C binding, so C doesn't really care about Fortran's PUBLIC|PRIVATE attributes. All that matters is whether the procedure name in the object file is either global (i.e., external) or local to the object. Since submodules can be in separate files (and might therefore be associated to separate object files), their procedure names have to be global.
(In fact, gfortran has a bug related submodules not seeing the parent module's private definitions because the generated object file for the module considers them local.)
Steve_Lionel
榮譽貢獻者 III
549 檢視
I think this is it.
回覆
