29649 Discussions
Bit field and Graphic library on Linux
brunocalado
I'm using the intel fortran compiler 11 on linux.
1 - ) Bit field
I want to create a long bit chain. Use the bits on Integer (Kind=8) is not enough. It must have the range 1-10000000.
The way I founded is create a array of logical
LOGICAL (KIND=1) :: gene( 10000 )
But it is very ugly because it allocated 10000 bytes instead bits. And I can't use the intrisic bit functions.
Is there a way of make true bit field?
2 - ) I tried to use the graphic library but it is just available for windows. Please make it work for linux.
tks
eliosh
Quoting - brunocalado
1 - ) Bit field
tks
1) I am afraid you will have to allocate an array of integers and access the bits manually.
2) not clear what library is "*the* graphics library" :)
brunocalado
Quoting - eliosh
There's functions for graphical interface. like arc pixels But they are available only for windows
INTEGER :: Array(5,10)
INTEGER :: tmp(5)
Array = 1
tmp = 2
Array(:,10) = tmp
Why the last line doesn't work?
How does it "not work"?
brunocalado
But I did the same here. Look:
LOGICAL (KIND=1) :: gene(5, 10)
INTEGER :: Index(10)
gene(:,:) = gene(:,Index)
Output:
Index Gene before (gene(:,:) = gene(:,Index))
1 : T F F T T
2 : T T T T T
3 : T T T T T
4 : T T F T T
5 : F T F T T
6 : F F F T T
7 : T F T F F
8 : T F T T T
9 : F F T T F
10 : T T F T F
Index before -> new Index Gene after (gene(:,:) = gene(:,Index))
1 -> 5 F T F T T
2 -> 1 T F F T T
3 -> 2 T T T T T
4 -> 3 T T T T T
5 -> 6 F F F T T
6 -> 8 T F T T T
7 -> 9 F F T T F
8 -> 4 T T F T T
9 -> 10 T T F T F
10 -> 7 T F T F F
The genes must change. The second (T T T T T) should go to the first position. The third (T T T T T) to the second...
It is the same thing, no?
eliosh
Output:
1 : T F F T T
2 : T T T T T
3 : T T T T T
4 : T T F T T
5 : F T F T T
6 : F F F T T
7 : T F T F F
8 : T F T T T
9 : F F T T F
10 : T T F T F
1 -> 5 F T F T T
2 -> 1 T F F T T
3 -> 2 T T T T T
4 -> 3 T T T T T
5 -> 6 F F F T T
6 -> 8 T F T T T
7 -> 9 F F T T F
8 -> 4 T T F T T
9 -> 10 T T F T F
10 -> 7 T F T F F
What can we see from this example ?????
Show the content of gene and Index before the permutation and after it.
brunocalado
updated
eliosh
updated
Your results look perfectly reasonable.
Note that the index change 1->5 means that the 5th element moves to the first position. Similarly, 2->4 means that the fourth element becomes the second.
For some reason you expect them to move in "reverse" direction.
brunocalado
Quoting - eliosh
Thank you.
This is what I want.
gene(:,Index) = gene(:,:)
