Boundary Run-Time Check Failure
Domenico_B_
Good morning.
I have a hybrid OpenMP/MPI code.
It compiles and runs successfully. I compile with:
mpiifort -qopenmp -mt_mpi
When I use option: -check stack, I get:
Boundary Run-Time Check Failure for variable 'cluster_$MMODEL'
forrtl: error (76): Abort trap signal
What is this telling me?
Do you need to see the source file? The complete error trace?
Thank you very much.
The problem is that MPI_WIN_GET_ATTR is writing wsize as an 8-byte integer (assuming you're building 64-bit). You declare it as a default integer which is 4 bytes. The stack check option correctly notices this and complains.
I'm having a hard time finding documentation to say what is supposed to happen here. I find that even if I do make wsize 8 bytes, the value it gets set to is, to my eyes, garbage.  I did find http://www.mpi-forum.org/docs/mpi-3.1/mpi31-report/node266.htm that suggests an address is returned, but the value I am seeing doesn't point to valid memory.
This is where my MPI knowledge stops (actually, it stopped fairly far back..) In any case, the basic issue is that wsize is incorrectly declared. I suggest declaring it as:
integer(int_ptr_kind()) :: wsize
What you do with the value is up to you.
This message is telling you that the program has corrupted the stack by writing outside the declared bounds of a variable. The error might not have been noticed without the optional stack checking and may not be harmful, but it is worth investigating.
Domenico_B_
ok, thanks. However, the simplest checks failed:
the option -CB does not give anything, so it's not an array problem
the variable mentioned in the error stream, cluster_$MMODEL, is an integer scalar.
It is, however, a cached variable for a window. So my first question is: do I have to include the memory for the cached variables (base, size, etc.) when I create the window? Also, is the memory for the window linked to this stack problem?
For your reference, I include here everything, i.e.:
- source: modules.f, windows2.f
- makefile. I compile with: make -f Makefile.MPI
- submission script. I ran with: ./MPI_interactive.sh 3
- output and error streams. The output is correct and the program does what it should.
- compiler: > mpiifort -v
mpiifort for the Intel(R) MPI Library 5.0 Update 3 for Linux*
Copyright(C) 2003-2015, Intel Corporation.  All rights reserved.
ifort version 15.0.2
- system: > uname -a
Linux imip15.ba.imip.cnr.it 2.6.32-504.8.1.el6.x86_64 #1 SMP Wed Jan 28 21:11:36 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
It would help me a lot if you could give me some tips.
Domenico_B_
Update: I was able to reduce the code to the bare minimum required to produce the error (attached)
No OpenMP, no computation. Just open the window, ask for the size, close the window. I also noticed the following:
1. If I don't ask for the size (with MPI_WIN_GET_ATTR) I don't get the error
2. If I do the same in the main, without the subroutine, I don't get the error
Domenico_B_
Solved !!
Everything works if the window attributes are declared as integer(KIND=MPI_ADDRESS_KIND).
Thank you very much for pointing me in the right direction.
