Break Points
reneeculver
Why are some breakpoints not honored?
ZCLYD = ICHAR('c')+256*(ICHAR('L')+ 256*(ICHAR('y')
1 +256*ICHAR('D')))
ALLSPACE = 32+256*(32+256*(32+256*32))
DO 1001 I=1,MAXLOC
IF(I.LE.MAXOBJ)PTEXT(I)=0
IF(I.LE.RTXSIZ)RTEXT(I)=0
IF(I.LE.CLSMAX)CTEXT(I)=0
IF(I.GT.LOCSIZ)GOTO 1001
STEXT(I)=0
LTEXT(I)=0
LOCCON(I)=0
1001 CONTINUE
DO 1278 I=1,MAXOBJ
POINTS(I)=0
1278 OBJCON(I)=0
Dim IOval
OPEN (UNIT=2,FILE='ADVDAT',STATUS='OLD',iostat = ioval) ! line 192
if ioval ne 0 then
dim a =2
end if
DO 1279 I=1,250
KEY(I) = 0
1279 CONTINUE
DO 1280 I = 1,50
1280 ADJKEY(I) = 0
Like a breapoint in front of the Open will not be honored. By the way, I found a .PDF of the fortran guide on the net.
Renee
onkelhotte
New Contributor II
Maybe Visual Studio gives you a hint: Dont confuse me with spaghetti code ;-)
It would be better to post this as code and not as text (the orange pen left to thy omega symbol).
Normally the debugger wont set a breakpoint when the code line is not reachable or the line redundant (for example i=i).
Markus
reneeculver
I does in this case...
To make matters worse, the are two projects in the solution and I keep flippng back and forth as to which project it is that's blowing up because there is no source. The display does show Intel assembler reliably.
There are masssive pieces of the loader that probably are not being called....hmmm.
Renee
jimdempseyatthecove
Renee,
"dim" is an elemental intrinsic function
or "d" in column 1 can be debug line indicator.
"Dim IOval"
"if ioval ne 0 then"
"dim a=2"
From the way you posted the code, it is difficult to tell what is happening.
Also, some parens seem to be missing.
Jim Dempsey
