Build error
reneeculver
000000013F593AF2 call 000000013F591A80
000000013F593AF7 mov dword ptr [rbp+384h],eax
000000013F593AFD mov eax,dword ptr [rbp+384h]
000000013F593B03 mov dword ptr [rbp+474h],eax
000000013F593B09 mov eax,dword ptr [rbp+460h]
000000013F593B0F test eax,eax
000000013F593B11 je 000000013F593CB6
000000013F593B17 mov eax,dword ptr [rbp+47Ch]
000000013F593B1D cmp eax,3
000000013F593B20 jne 000000013F593CB6
000000013F593B26 mov rax,qword ptr [13F642440h]
000000013F593B2D mov eax,dword ptr [rax+8]
000000013F593B30 test eax,eax
000000013F593B32 jne 000000013F593CB6
000000013F593B38 int 3
000000013F593B39 jmp 000000013F593CB6
000000013F593B3E mov eax,dword ptr [rbp+3F4h]
000000013F593B44 test eax,eax
000000013F593B46 jne 000000013F593B7E
000000013F593B48 mov rax,qword ptr [13F642440h]
000000013F593B4F test rax,rax
000000013F593B52 je 000000013F593B7E
000000013F593B54 mov eax,dword ptr [rbp+45Ch]
000000013F593B5A cmp eax,1
This error has been troubleome because It's build error which leaves me no Source. Can someone help as it doesn't give me much to go on.
The breakage is at 000000013F593B38
Renee
This is not a build error. You have some sort of run-time error. Is there a terminal window hidden behind the Visual Studio window? This may have details of the error.
reneeculver
No, It was equivalent to a console task as it is the adventure taskyou sent. I think of the two projects it is the setup process.
I call it a build error because I never see the program run.
By the way, I didn't have any blue-rays to backup the system. Today I paid 100.00 to go to microcenter and get some blue rays. I am backing up the system as I wrie.
Renee
mecej4
You provided no context for the machine code dump extract that you gave. Which process produced this dump? Is it the dump of an .EXE, a .DLL, and which one? Are you really debugging at the assembly level?
If at address 000000013F593B30 Register eax is zero an interrupt 3 is taken. What happens then depends on the current handler for the interrupt.
When you run a console application (as Adventure is), it creates a console window. Sometimes, when an error occurs, the console window has the real error message but it is hidden by the Visual Studio window, so look in the taskbar to see if there is an additional window and bring it forward.
Most likely there is a detailed error message in the console window.
reneeculver
No, It was equivalent to a console task as it is the adventure task you sent. I think of the two projects it is the setup process.
By the way, I didn't have any blue-rays to backup the system. Today I paid 100.00 to go to microcenter and get some blue rays. I am backing up the system as I wrtie.
Renee
