SPR
11/04/2016
O/S:
Windows 7 Professional
ifort switches:
/compile_only
/static
/noautomatic
/list
/warn:nogeneral
/traceback
/map
/align:rec4byte
/optimize:4
/assume:byterecl
/extend_source
/fltconsistency
/vms
ifort version:
Intel(R) Visual Fortran Compiler Professional for applications running on IA-32, Version 11.1
Build 20090930 Package ID: w_cprof_p_11.1.048
Copyright (C) 1985-2009 Intel Corporation. All rights reserved.
Issue: Array OPR6 is not being computed unless VOLATILE statement is
implemented.
Directions: compile and link with VOLATILE statement commented out and
not commented out. Observe the output is different. OPR6 is
an array that is entirely contained within main() and should
not fail under optimization.
IMPLICIT INTEGER (A-Z) PARAMETER MO=9999,MR=9999,MF=9999 INTEGER OPR6(0:MO),OPR9(0:MR),OPR8(0:MR),TREE(0:MO) INTEGER OPR1(0:MR),OPR2(0:MO),OPR3(0:MF),OPR4(0:MF),OPR5(0:MR),OPR7(0:MF) INTEGER*8 OPRA(0:MR),OPRB(0:MR),OPRT(0:MO) VOLATILE OPR6 PA1=-1 PA2=-1 KID=0 DO OBJ=1,5 IF(PA1.EQ.MR) GOTO 101 PA1=PA1+1 OPR1(PA1)=OBJ OPR2(OBJ)=MAX(OBJ-1,0) OPR8(PA1)=PA2+1 OPRA(OBJ)=PA1 DO I=1,5 IF(PA2.EQ.MF) GOTO 101 PA2=PA2+1 OPR3(PA2)=OBJ+100 OPR4(PA2)=OBJ OPR7(PA2)=PA1 END DO KID=MAX(KID,PA2-OPR8(PA1)+1) END DO WHO=OBJ K=0 DO I=0,PA1 H=0 OBJ=OPR1(I) DO WHILE (OPR2(OBJ).NE.0) OBJ=OPR2(OBJ) H=H+1 END DO OPR5(I)=H K=MAX(K,H) END DO IF(K.GT.MR) GOTO 102 DO I=1,K CALL HEAPXA_INIT(WHO,TREE) DO J=0,PA1 IF(OPR5(J).EQ.I) CALL HEAPXA_PUT2(OPR1(J),TREE) END DO H=0 DO WHILE (HEAPXA_GET2(OBJ,TREE).EQ.0) H=H+1 OPR6(OBJ)=H END DO OPR9(I)=H+1 END DO IF(K.EQ.MR) GOTO 102 OPRB(K)=KID DO I=K-1,1,-1 IF(BITSX(OPRB(I+1))+BITSX(OPR9(I+1)).GT.63) GOTO 103 OPRB(I)=OPRB(I+1)*OPR9(I+1) END DO OBJ1=0 DO I=0,PA2 OBJ=OPR4(I) P=OPR7(I) J=I-OPR8(P) IF(OBJ.EQ.OBJ1) THEN LONG=LONG/KID*KID+J ELSE OBJ1=OBJ LONG=J DO WHILE (OPR2(OBJ).NE.0) LONG=LONG+OPR6(OBJ)*OPRB(OPR5(OPRA(OBJ))) OBJ=OPR2(OBJ) END DO ENDIF OBJ=OPR3(I) OPRT(OBJ)=LONG WRITE(6,*) OBJ,LONG END DO 100 CALL EXIT 101 WRITE(6,*) '%PDTXT - increase MF' CALL EXIT 102 WRITE(6,*) '%PDTXT - increase MR' CALL EXIT 103 WRITE(6,*) '%PDTXT - tree failure' CALL EXIT END SUBROUTINE HEAPXA IMPLICIT INTEGER (A-Z) INTEGER TREE(0:1) DATA EOH/'80000000'X/ ENTRY HEAPXA_INIT(SIZ,TREE) SIZE=SIZ LAST=0 TREE(1)=EOS RETURN ENTRY HEAPXA_PUT2(WHO,TREE) LAST=LAST+1 IF(LAST.GT.SIZE) GOTO 10 IF(WHO.EQ.EOH) GOTO 11 TREE(LAST)=WHO I=LAST 1 J=ISHFT(I,-1) IF(J.EQ.0) RETURN K=TREE(J) IF(K.LE.WHO) RETURN TREE(J)=WHO TREE(I)=K I=J GOTO 1 ENTRY HEAPXA_GET2(WHO,TREE,*) WHO=TREE(1) IF(WHO.EQ.EOH) RETURN 1 I=1 2 J=ISHFT(I,1) IF(J-LAST) 5,3,4 3 K=TREE(J) IF(K.EQ.EOH) THEN 4 TREE(I)=EOH RETURN ENDIF TREE(I)=K TREE(J)=EOH RETURN 5 K=TREE(J) N=J+1 L=TREE(N) IF(K.EQ.EOH) THEN IF(L.EQ.EOH) GOTO 4 TREE(I)=L I=N GOTO 2 ELSE IF(L.EQ.EOH) THEN TREE(I)=K I=J GOTO 2 ENDIF IF(K-L) 6,7,8 6 TREE(I)=K I=J GOTO 2 7 IF(K.LT.L) THEN TREE(I)=K I=J ELSE TREE(I)=L I=N ENDIF GOTO 2 8 TREE(I)=L I=N GOTO 2 10 WRITE(6,*) '%HEAPXA - memory exceeded' CALL EXIT 11 WRITE(6,*) '%HEAPXA - use HEAPXA when some values equal 80000000x' CALL EXIT END INTEGER FUNCTION BITSX(VALUE1) IMPLICIT INTEGER (A-Z) INTEGER*8 POW(0:64),VALUE,VALUE1 DATA POW/ * 1, * 2, * 4, * 8, * 16, * 32, * 64, * 128, * 256, * 512, * 1024, * 2048, * 4096, * 8192, * 16384, * 32768, * 65536, * 131072, * 262144, * 524288, * 1048576, * 2097152, * 4194304, * 8388608, * 16777216, * 33554432, * 67108864, * 134217728, * 268435456, * 536870912, * 1073741824, * 2147483648, * 4294967296, * 8589934592, * 17179869184, * 34359738368, * 68719476736, * 137438953472, * 274877906944, * 549755813888, * 1099511627776, * 2199023255552, * 4398046511104, * 8796093022208, * 17592186044416, * 35184372088832, * 70368744177664, * 140737488355328, * 281474976710656, * 562949953421312, * 1125899906842624, * 2251799813685248, * 4503599627370496, * 9007199254740992, * 18014398509481984, * 36028797018963968, * 72057594037927936, * 144115188075855872, * 288230376151711744, * 576460752303423488, * 1152921504606846976, * 2305843009213693952, * 4611686018427387904, * 9223372036854775807/ IF(VALUE1.EQ.0) THEN BITSX=0 RETURN ELSE IF(VALUE1.GT.0) THEN VALUE=VALUE1 ELSE VALUE=-VALUE1 ENDIF J1=0 J2=64 I=32 1 IF(VALUE.LE.POW(I)) THEN J2=I ELSE J1=I+1 ENDIF IF(J1.NE.J2) THEN I=(J1+J2)/2 GOTO 1 ENDIF IF(VALUE.LT.POW(J1)) THEN BITSX=J1 ELSE BITSX=J1+1 ENDIF END
Your program seems to depend on some non-standard extensions, and I don't know what it is supposed to do. It uses the old VMS style PARAMETER statement, but also the attribute VOLATILE, which did not exist in Fortran 95.
One thing stands out: the undefined variable EOS is used in HEAPXA. What do you expect its value to be? Zero?
The program in #3 gives the same results with and without the VOLATILE statement with IFort 11.1.070. Same with 2017 Update 1.
You're using a compiler that is seven years old. Can you reproduce the problem with the current version 17.0.1?
Some issues I see with the code. In BITSX, you declare POW to be (0:64), which is 65 elements, but you supply only 64 values. On lines 123 and 136 you have branches to label 4 which are inside an IF-THEN block. This is not legal in Fortran and can result in incorrect execution.
When I run the program I get:
I don't understand the logic flow that leads to this.
Lastly, I'll comment that we don't have an optimization level higher than 3. For compatibility with DEC/Compaq compilers that had up to a level 5, we accept 4 and 5 but map them to 3.
If you can tell me how to correct the "memory exceeded" problem I'll try again, but the illegal branches into blocks could be problematic with optimization.
I've attached a version that is free-form formatted - the inline insertion button doesn't do well with tab formatting.
Hi Steve,
I fixed the branches into IF blocks. It has been my experience that branches into IF blocks don't cause any harm if done properly. In any case, I changed the code so that doesn't happen in this example. Yes, 0:63 is better. Thanks for your insightful comment here. There was an issue when the value was 2**63-1 (because I can't store 2**63 in a 64-bit signed integer, so I stored 2**63-1 in the 63rd position) - it gave the wrong answer - however that was unrelated to the bug at hand here.
You should never get a HEAPAX memory exceeded error (I don't get that). Basically, the maximum number of calls to HEAPAX_PUT2 should not exceed the first argument to HEAPAX_INIT - which is WHO - which equals 6. So I don't understand why you would be getting this error. Maybe you dropped the statement that defined WHO = OBJ?? Try setting WHO = 6 directly.
As an aside, FORTRAN is 10X (yes 10 times!) faster than the most expensive and best code being sold today to do the job that this program does...And it is 50X ( 50 times!) faster than the cheapest code commercially available.
Here is the code with all tabs replaced with 8 spaces.
IMPLICIT INTEGER (A-Z) PARAMETER MO=9999,MR=9999,MF=9999 INTEGER OPR6(0:MO),OPR9(0:MR),OPR8(0:MR),TREE(0:MO) INTEGER OPR1(0:MR),OPR2(0:MO),OPR3(0:MF),OPR4(0:MF),OPR5(0:MR),OPR7(0:MF) INTEGER*8 OPRA(0:MR),OPRB(0:MR),OPRT(0:MO) VOLATILE OPR6 PA1=-1 PA2=-1 KID=0 DO OBJ=1,5 IF(PA1.EQ.MR) GOTO 101 PA1=PA1+1 OPR1(PA1)=OBJ OPR2(OBJ)=MAX(OBJ-1,0) OPR8(PA1)=PA2+1 OPRA(OBJ)=PA1 DO I=1,5 IF(PA2.EQ.MF) GOTO 101 PA2=PA2+1 OPR3(PA2)=OBJ+100 OPR4(PA2)=OBJ OPR7(PA2)=PA1 END DO KID=MAX(KID,PA2-OPR8(PA1)+1) END DO WHO=OBJ K=0 DO I=0,PA1 H=0 OBJ=OPR1(I) DO WHILE (OPR2(OBJ).NE.0) OBJ=OPR2(OBJ) H=H+1 END DO OPR5(I)=H K=MAX(K,H) END DO IF(K.GT.MR) GOTO 102 DO I=1,K CALL HEAPXA_INIT(WHO,TREE) DO J=0,PA1 IF(OPR5(J).EQ.I) CALL HEAPXA_PUT2(OPR1(J),TREE) END DO H=0 DO WHILE (HEAPXA_GET2(OBJ,TREE).EQ.0) H=H+1 OPR6(OBJ)=H END DO OPR9(I)=H+1 END DO IF(K.EQ.MR) GOTO 102 OPRB(K)=KID DO I=K-1,1,-1 IF(BITSX(OPRB(I+1))+BITSX(OPR9(I+1)).GT.63) GOTO 103 OPRB(I)=OPRB(I+1)*OPR9(I+1) END DO OBJ1=0 DO I=0,PA2 OBJ=OPR4(I) P=OPR7(I) J=I-OPR8(P) IF(OBJ.EQ.OBJ1) THEN LONG=LONG/KID*KID+J ELSE OBJ1=OBJ LONG=J DO WHILE (OPR2(OBJ).NE.0) LONG=LONG+OPR6(OBJ)*OPRB(OPR5(OPRA(OBJ))) OBJ=OPR2(OBJ) END DO ENDIF OBJ=OPR3(I) OPRT(OBJ)=LONG WRITE(6,*) OBJ,LONG END DO 100 CALL EXIT 101 WRITE(6,*) '%PDTXT - increase MF' CALL EXIT 102 WRITE(6,*) '%PDTXT - increase MR' CALL EXIT 103 WRITE(6,*) '%PDTXT - tree failure' CALL EXIT END SUBROUTINE HEAPXA IMPLICIT INTEGER (A-Z) INTEGER TREE(0:1) DATA EOH/'80000000'X/ ENTRY HEAPXA_INIT(SIZ,TREE) SIZE=SIZ LAST=0 TREE(1)=EOS RETURN ENTRY HEAPXA_PUT2(WHO,TREE) LAST=LAST+1 IF(LAST.GT.SIZE) GOTO 10 IF(WHO.EQ.EOH) GOTO 11 TREE(LAST)=WHO I=LAST 1 J=ISHFT(I,-1) IF(J.EQ.0) RETURN K=TREE(J) IF(K.LE.WHO) RETURN TREE(J)=WHO TREE(I)=K I=J GOTO 1 ENTRY HEAPXA_GET2(WHO,TREE,*) WHO=TREE(1) IF(WHO.EQ.EOH) RETURN 1 I=1 2 J=ISHFT(I,1) IF(J-LAST) 5,3,4 3 K=TREE(J) IF(K.EQ.EOH) GOTO 4 TREE(I)=K TREE(J)=EOH RETURN 4 TREE(I)=EOH RETURN 5 K=TREE(J) N=J+1 L=TREE(N) IF(K.EQ.EOH) THEN IF(L.EQ.EOH) GOTO 4 TREE(I)=L I=N GOTO 2 ELSE IF(L.EQ.EOH) THEN TREE(I)=K I=J GOTO 2 ENDIF IF(K-L) 6,7,8 6 TREE(I)=K I=J GOTO 2 7 IF(K.LT.L) THEN TREE(I)=K I=J ELSE TREE(I)=L I=N ENDIF GOTO 2 8 TREE(I)=L I=N GOTO 2 10 WRITE(6,*) '%HEAPXA - memory exceeded' CALL EXIT 11 WRITE(6,*) '%HEAPXA - use HEAPXA when some values equal 80000000x' CALL EXIT END INTEGER FUNCTION BITSX(VALUE1) IMPLICIT INTEGER (A-Z) INTEGER*8 POW(0:63),VALUE,VALUE1 DATA POW/ * 1, * 2, * 4, * 8, * 16, * 32, * 64, * 128, * 256, * 512, * 1024, * 2048, * 4096, * 8192, * 16384, * 32768, * 65536, * 131072, * 262144, * 524288, * 1048576, * 2097152, * 4194304, * 8388608, * 16777216, * 33554432, * 67108864, * 134217728, * 268435456, * 536870912, * 1073741824, * 2147483648, * 4294967296, * 8589934592, * 17179869184, * 34359738368, * 68719476736, * 137438953472, * 274877906944, * 549755813888, * 1099511627776, * 2199023255552, * 4398046511104, * 8796093022208, * 17592186044416, * 35184372088832, * 70368744177664, * 140737488355328, * 281474976710656, * 562949953421312, * 1125899906842624, * 2251799813685248, * 4503599627370496, * 9007199254740992, * 18014398509481984, * 36028797018963968, * 72057594037927936, * 144115188075855872, * 288230376151711744, * 576460752303423488, * 1152921504606846976, * 2305843009213693952, * 4611686018427387904, * 9223372036854775807/ IF(VALUE1.EQ.0) THEN BITSX=0 RETURN ELSE IF(VALUE1.GT.0) THEN VALUE=VALUE1 ELSE VALUE=-VALUE1 ENDIF J1=0 J2=63 I=32 1 IF(VALUE.LE.POW(I)) THEN J2=I ELSE J1=I+1 ENDIF IF(J1.NE.J2) THEN I=(J1+J2)/2 GOTO 1 ENDIF IF(VALUE.LT.POW(J1)) THEN BITSX=J1 ELSE IF(J1.EQ.63) THEN BITSX=J1 ELSE BITSX=J1+1 ENDIF END
Be careful of line 28 (WHO=OBJ).
Depending on version of compiler (early F66/F77), the termination value of the loop may be the last one used in the loop or one step increment after (assuming no loop bail-out). As written now, the value used is 6.
Jim Dempsey
As you have a mixture of features from F66 and later standards, which you like to use in incompatible combinations, Jim's caution may be well taken. F77 did specify the "next" value of loop counter as the one set after loop termination, but that was one of the last features of F77 to be widely implemented, around 1983 in some compilers. F66 had no rule. One of the F66 compilers I used (Honeywell) had 3 different treatments in the same compiler, depending on the optimization level, and an F77 compiler (HP/KAP) required a specific directive to get the standard treatment.
I wonder if that EOS was supposed to be EOH.
Yes EOS was supposed to be EOH - unfortunately that made no difference in the outcome...
I am using 11.1.048 and you are telling me that version 11.1.070 has since fixed this bug.
This is good news and justification enough to upgrade to the latest version.
Thanks for all your effort and great suggestions, everyone !
John
Just to make sure, is this what 11.1.070 and 2017 update 1 produced as output:?
101 0
101 1
101 2
101 3
101 4
102 40
102 41
102 42
102 43
102 44
103 60
103 61
103 62
103 63
103 64
104 70
104 71
104 72
104 73
104 74
105 75
105 76
105 77
105 78
105 79
Yes, that is the output I see, but I am afraid that your program is firmly lodged in my basket of deplorables. The following are some of the reasons, in addition to those that I mentioned earlier.
- HEPXA_GET2 is a subroutine secondary ENTRY with one alternate return argument. It is invoked as an integer function.
- Function BITSX is invoked with an INTEGER*4 argument whereas an INTEGER*8 is expected.
IMPLICIT NONE is the king of all Fortran commands. It eliminates so many coding errors!
Here is a cleaned up version of OP's program that does not depend on extensions to the language or require a perfect alignment of the planets to give correct results. It will probably work even with the 11.1.048 version of IFort.
MODULE heapxa IMPLICIT NONE INTEGER, PARAMETER :: eoh = huge(0) INTEGER, PARAMETER :: i8 = SELECTED_INT_KIND(15) INTEGER, SAVE :: last, tsize CONTAINS SUBROUTINE heapxa_init(siz, tree) IMPLICIT NONE INTEGER, DIMENSION (0:1) :: tree INTEGER, INTENT(IN) :: siz tsize = siz last = 0 tree(1) = eoh RETURN END SUBROUTINE heapxa_init SUBROUTINE heapxa_put2(who, tree) IMPLICIT NONE INTEGER, DIMENSION (0:1) :: tree INTEGER :: i, j, k, who last = last + 1 IF (last>tsize) GO TO 100 IF (who==eoh) GO TO 110 tree(last) = who i = last DO j = ishft(i, -1) IF (j==0) RETURN k = tree(j) IF (k<=who) RETURN tree(j) = who tree(i) = k i = j END DO 100 WRITE (6, *) '%HEAPXA - memory exceeded' CALL exit 110 WRITE (6, *) '%HEAPXA - use HEAPXA when some values equal HUGE(0)' CALL exit END SUBROUTINE heapxa_put2 FUNCTION heapxa_get2(who, tree) RESULT (rv) IMPLICIT NONE INTEGER, DIMENSION (0:1) :: tree INTEGER rv INTEGER :: i, j, k, l, n, who who = tree(1) rv = 0 IF (who==eoh) THEN rv = 1 RETURN END IF i = 1 DO j = ishft(i, 1) IF (j > last) THEN tree(i) = eoh RETURN ELSE IF(j == last) THEN k = tree(j) IF (k==eoh) THEN tree(i) = eoh RETURN END IF tree(i) = k tree(j) = eoh RETURN END IF k = tree(j) n = j + 1 l = tree(n) IF (k==eoh) THEN IF (l==eoh) THEN tree(i) = eoh RETURN END IF tree(i) = l i = n CYCLE ELSE IF (l==eoh) THEN tree(i) = k i = j CYCLE END IF IF (k > l) THEN tree(i) = l i = n CYCLE END IF IF (k < l) THEN tree(i) = k i = j ELSE tree(i) = l i = n END IF END DO END FUNCTION heapxa_get2 INTEGER FUNCTION bitsx(value1) IMPLICIT NONE INTEGER(i8) :: value, value1 INTEGER :: j j = 64 value = abs(value1) DO WHILE (j>0) j = j - 1 IF (btest(value,j)) EXIT END DO IF (btest(value,j)) j = j + 1 bitsx = j RETURN END FUNCTION bitsx END MODULE heapxa PROGRAM jajdavid USE heapxa IMPLICIT NONE INTEGER, PARAMETER :: mo=9999, mr=9999, mf=9999 INTEGER, DIMENSION(0:mo) :: opr2, opr6, tree INTEGER, DIMENSION(0:mr) :: opr1, opr5, opr8, opr9 INTEGER, DIMENSION(0:mf) :: opr3, opr4, opr7 INTEGER(i8) :: opra(0:mr), oprb(0:mr), oprt(0:mo) INTEGER :: pa1, pa2, kid, obj, obj1, who, i, j, k, h, p, long pa1 = -1 pa2 = -1 kid = 0 DO obj = 1, 5 IF (pa1==mr) GO TO 100 pa1 = pa1 + 1 opr1(pa1) = obj opr2(obj) = max(obj-1, 0) opr8(pa1) = pa2 + 1 opra(obj) = pa1 DO i = 1, 5 IF (pa2==mf) GO TO 100 pa2 = pa2 + 1 opr3(pa2) = obj + 100 opr4(pa2) = obj opr7(pa2) = pa1 END DO kid = max(kid, pa2-opr8(pa1)+1) END DO who = obj k = 0 DO i = 0, pa1 h = 0 obj = opr1(i) DO WHILE (opr2(obj)/=0) obj = opr2(obj) h = h + 1 END DO opr5(i) = h k = max(k, h) END DO IF (k>mr) GO TO 110 DO i = 1, k CALL heapxa_init(who, tree) DO j = 0, pa1 IF (opr5(j)==i) CALL heapxa_put2(opr1(j), tree) END DO h = 0 DO WHILE (heapxa_get2(obj,tree)==0) h = h + 1 opr6(obj) = h END DO opr9(i) = h + 1 END DO IF (k==mr) GO TO 110 oprb(k) = kid DO i = k - 1, 1, -1 IF (bitsx(oprb(i+1))+bitsx(int(opr9(i+1),8))>63) GO TO 120 oprb(i) = oprb(i+1)*opr9(i+1) END DO obj1 = 0 DO i = 0, pa2 obj = opr4(i) p = opr7(i) j = i - opr8(p) IF (obj==obj1) THEN long = long/kid*kid + j ELSE obj1 = obj long = j DO WHILE (opr2(obj)/=0) long = long + opr6(obj)*oprb(opr5(opra(obj))) obj = opr2(obj) END DO END IF obj = opr3(i) oprt(obj) = long WRITE (6, *) obj, long END DO CALL exit 100 WRITE (6, *) '%PDTXT - increase MF' CALL exit 110 WRITE (6, *) '%PDTXT - increase MR' CALL exit 120 WRITE (6, *) '%PDTXT - tree failure' CALL exit END PROGRAM jajdavid SUBROUTINE exit() STOP 'Exit called' END SUBROUTINE exit
Looks good mecej4, all that old old style Fortran upsets my eyes! Much more readable and will compile with all that bug stopping checking and standards checking options....
I am intrigued, what does this program that takes no external input do?
The answer to mecej4 is
No, your spruced up code does not run correctly under 11.1.048. Your changes are purely cosmetic as far as the compiler is concerned.
However, it is true OPR9 is misclassified as INTEGER*4 when it should be INTEGER*8. Thanks for that!
I apologize for hurting anybody's eyes. I am very happy with F77 and have no plans to "improve" my code, of which I have an extensive library, all written in F77/VMS.
Finally to answer the question as to what this code is about.
First, this code is a very small extract of a much bigger and complex program. The code was created to give Intel something relatively manageable that demonstrated the 11.1.048 complier bug. I was most curious to see if this bug had been fixed in subsequent versions of Intel FORTRAN so I could make a case for myself to upgrade to the latest version.
Finally, what does this program do? It reads raw PDF's, formats them as text using a configuration file that allows for manipulation of the PDF (such as removing columns and translating different languages into "phonetic ASCII" ) then runs a specialized script (unique to each PDF) that extracts the text data so it may be loaded into a given database. As an example, it will process a 30,000 page AT&T Mobility invoice in under 2 minutes, extracting all the billing information (charges, call detail) so it may be loaded into a target database. Just for comparison purposes, using commercially available software, thus can not be done in under 20 minutes. When you have 10,000 PDF's to process a day, being 10X faster makes a big difference.
You may be asking yourself the question "why process PDF's?" Isn't everything available in more manageable formats (like XML, CSV etc)? The answer to that is in two parts. One, PDF's sometimes contain specialized information not available in any other format. Two, in some cases, no other format is available.
I call this program CAPTURE. As far as I know, CAPTURE is unique.
CAPTURE is entirely written in F77, my favorite language..
Thanks for the explanation of the purpose of your program. The application is interesting, and I had done similar data extraction work using a commercial PDF library a few years ago.
I tried the program of #13 with (i) IFort 7.0 of 2002/10/28 and (ii) IFort 9.1.0 of 2007/10/16. In both cases, no errors, same results. The question then is: What is special about 11.1.048, given that none of the earlier and later versions that I tried do not show a bug?
With regard to your CAPTURE application: does it spend a good portion of its run time in function BITSX? Or one of the other subroutines that you showed in your test program? Note that BITSX can be efficiently implemented using the X86/X64 BSR instruction. Here is the 64-bit version:
_TEXT SEGMENT public BITSX BITSX proc mov rax,qword ptr [rcx] test rax,rax jne l1 ret l1: jns l2 neg rax l2: bsr rax,rax inc eax ret BITSX endp end
I don't know what the comparative capabilities of V11 of the compiler were it is a long time ago but I will say that during the course of this thread a number of bugs in the short original code have been identified all of which would have been thrown up by the latest compiler with appropriate checking options set and if speed it one of your primary concerns then that also should improve with an upgrade.
For what it is worth my personal option is the that restructure is far more than cosmetic is allows for easier readability maintenance and the elimination of coding errors and/or code that relies on non-standard and hence unpredictable compiler behaviour.
To answer your question, my program spends and insignificant amount of time in BITS so changing it wouldn't have any impact on the performance of the program. But it is nice to know about and It certainly would be nice if BSR (and BSF) were implemented in FORTRAN...
