29386 Discussions
Bug? Strange error raised by `ifort -check shape`
Zaikun
Hello!
I have encountered a strange error raised by `ifort -check shape` with `ifort (IFORT) 2021.2.0 20210228`. Here is a minimal working example.
! testshape.f90
program testshape
implicit none
integer :: a(1, 2)
a(:, 1:2) = a(:, 1:2) ! This line is OK. Benchmark for the erroneous line.
a(:, [1, 2]) = a(:, [1, 2]) ! Do nothing ..., but it triggers the error.
end program testshape
Name this code as `testshape.f90`, and then compile it. Here is what happens on my machine (Ubuntu 20.04).
$ ifort -check shape testshape.f90
testshape.f90(7): error #5581: Shape mismatch: The extent of dimension 1 of array A is 1 and the corresponding extent of array <RHS expression> is 2
compilation aborted for testshape.f90 (code 1)
If we remove `-check shape` or replace it with `-warn shape`, then everything works.
Did I misunderstand array indexing or miscalculate something in the code? Thank you for your attention.
Devorah_H_Intel
The fix is coming in the next Intel Fortran Compiler release 2021.7
mecej4
Some characters in the code part of your post have disappeared. Please edit your post and display the code using the code button (click on ..., then on </>).
Zaikun
mecej4
The bug is not present in older versions of Ifort, such as 2013SP1 and 2016.0.8.
Zaikun
Thank you for the verification. It seems that `-check shape` has not been available until 2018:
https://software.intel.com/content/www/us/en/develop/articles/array-shape-check-new-in-intel-fortran-compiler-190.html
Thank you.
Zaikun
Hello,@VidyalathaB_Intel ! Sorry to bother you, but I do believe this is a bug. Thanks.
Barbara_P_Intel
Thanks for reporting this. I filed a bug report on your behalf, CMPLRIL0-34245. I'll keep you posted on its progress to a fix.
Devorah_H_Intel
