29336 Discussions
vs2019 16.11.16 cannot creat or open ivf project
phost75
same problems with vs 2022.It looks like vs'upgrade is bad idea
JohnNichols
Valued Contributor III
16.11.16 is working normally with Fortran.  You likely made an integration install error.   I had that problem on another computer.
Devorah_H_Intel
Click on Help> About - check if Intel Compilers are listed there.
If they are not integrated, then check if you configured VS correctly.
