Bug in ifx 2023.0.0?
andreasskeidsvoll
The following minimal example
module module_name
  type :: object
    integer :: i
  contains
    final :: finalize_object
  end type object
  interface object
    procedure :: intialize_object
  end interface object
contains
  function intialize_object() result(this)
    type(object) :: this
    this%i = 0
  end function intialize_object
  subroutine finalize_object(this)
  end subroutine finalize_object
  subroutine first_subroutine()
    type(object) :: object_instance
    object_instance = object()
  end subroutine first_subroutine
  subroutine second_subroutine()
  end subroutine second_subroutine
end module module_name
fails compile with ifx 2023.0.0 with the -fopenmp flag
ifx main.F90 -c -fopenmp
on my Dell Latitude 7410 laptop with Ubuntu 22.10, giving the following error message
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1f563ca]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1bef70e]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1c55e52]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1c55f80]
/lib/x86_64-linux-gnu/libc.so.6(+0x3bcf0)[0x7f539163bcf0]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x38bd73f]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x38bc334]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x38b98d1]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x2d1fcfd]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x2031303]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x2d1ad2d]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x2847992]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x2d303ed]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x28435ea]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x2b6549d]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x2845b88]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x2b658bd]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x2844b9c]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x2b6567d]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x202fe87]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x2b622fb]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x2d1dabd]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1b96f59]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1b955dd]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1b44a74]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1d028ee]
/lib/x86_64-linux-gnu/libc.so.6(+0x23510)[0x7f5391623510]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x89)[0x7f53916235c9]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1982da9]
/tmp/ifx0396505090Uv3g06/ifxClMdEY.i90: error #5633: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for main.F90 (code 3)
 For some reason, the compilation succeeds when any of the subroutines or the -fopenmp flag is removed. Is this a bug in the compiler?
Barbara_P_Intel
Thanks for reporting this. It sounds familiar, but I can't find a bug report. I filed a new one, CMPLRLLVM-42903.
This compiles OK with ifort -qopenmp.
FYI... -qopenmp and -fiopenmp are equivalent. -fopenmp is deprecated. I've been told that -qopenmp has some Intel enhancements, no proof tho.
andreasskeidsvoll
Tested with the -qopenmp and -fiopenmp flags, giving the same error.
Barbara_P_Intel
Barbara_P_Intel
The latest release of ifx available in oneAPI HPC Toolkit 2023.1 enables this reproducer to compile just fine. This compiler was released this week.
Please try it!
