29424 Discussions
Getting an ICE with ifx 2023 when passing substrings as arguments that will get a returned value
ur
New Contributor II
This reduced example generates an ICE using ifx(1) when a substring is
passed as an argument that is returned. Works fine with several other
compilers.
program substring_bug
implicit none
type argstr
character(len=:), allocatable :: string
end type argstr
type(argstr) :: args
args%string=repeat('=',80)
call get_command_argument(0,args%string(15:65))
write(*,'(g0)')args%string
end program substring_bug
+ fpm run --compiler gfortran
==============build/gfortran_2A42023B310FA28D/app/ICE ===============
+ fpm run --compiler ifort
==============build/ifort_5C58216731706F11/app/ICE ===============
+ fpm run --compiler ifx
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1f563ca]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1bef70e]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0x147bf6768083]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1982da9]
app/main.f90(11): error #5623: **Internal compiler error: internal
abort** Please report this error along with the circumstances in which
it occurred in a Software Problem Report. Note: File and line given
may not be explicit cause of this error.
Barbara_P_Intel
@ur, thanks for putting ifx through its paces! I filed a bug report, CMPLRLLVM-42933.
Barbara_P_Intel
Barbara_P_Intel
This ICE is fixed in the Fortran compiler that was released this week as part of oneAPI HPC Toolkit 2023.1.
Please check it out!
ur
New Contributor II
Works with the new ifort and ifx. Thanks!
