the code:
Module testmod
Type :: root_type
integer, allocatable :: a
contains
Generic, Public :: Assignment(=) => Copy
Procedure, Pass(this) :: Copy => SubCopy
End type root_type
Type, extends(root_type) :: child_type
End type child_type
contains
Subroutine SubCopy(other,this)
Class(root_type), Intent(In) :: this
Class(root_type), Intent(InOut) :: other
Allocate(other%a,source=this%a)
end Subroutine SubCopy
End Module testmod
Program Test
Use testmod, only: child_type
Type(child_type), allocatable :: x,y
allocate(x)
allocate(y,source=x)
end Program Test
compiles with ifort 17.05 to 18.01 and with gfortran 7.2, but the ifort exec yields a seg fault at run time:
forrtl: severe (174): SIGSEGV, segmentation fault occurred Image PC Routine Line Source a.out 000000000040396D Unknown Unknown Unknown libpthread-2.26.s 000014D0F3566DA0 Unknown Unknown Unknown a.out 0000000000402A8E Unknown Unknown Unknown a.out 00000000004029DE Unknown Unknown Unknown libc-2.26.so 000014D0F31BDF4A __libc_start_main Unknown Unknown a.out 00000000004028EA Unknown Unknown Unknown
workaround is to either use "root_type" directly, or to comment the generic assignment. I am almost certain that this is a bug, but maybe others can confirm or tell me what I did wrong.
Cheers
The standard specifies for the ALLOCATE statement, "If source-expr is allocatable, it shall be allocated." which is not the case in the code you show: in your SubCopy procedure, the instructions need to take into account whether this%a is allocated.
You mean that one would need something like:
if(allocated(this%a) then Allocate(other%a,source=this%a) End if
That also seems to solve the seg fault.
THANK YOU.
if(allocated(this%a) then Allocate(other%a,source=this%a) End if!? ..
Yep.
