Bug with omitted optional intent out arguments of an abstract type
Nicholas_B_
The Intel Parallel Studio XE 2017 Fortran compiler produces code which crashes with omitted optional intent out arguments of an abstract type.
The previous version of the compiler did not have this problem:
forrtl: severe (157): Program Exception - access violation
program prog
  use sub_module
  use simple_exception_module
  implicit none
  type(simple_exception_type) :: exception
  character(:), allocatable :: message
  call sub( exception )
  if ( exception%catch( message ) ) then
    write(*,*) message
  end if
  call sub() ! crashes here
end program prog
module sub_module
  use exception_module
  implicit none
contains
  subroutine sub( exception )
    class(exception_type), intent(out), optional :: exception
    if ( present( exception ) ) then
      call exception%throw( 'Exception in sub' )
    end if
  end subroutine sub
end module sub_module
module simple_exception_module
  implicit none
  private
  type, extends(exception_type), public :: simple_exception_type
    character(:), allocatable, private :: message
  contains
    procedure :: throw
    procedure :: catch
  end type simple_exception_type
contains
  subroutine throw( exception, message )
    class(simple_exception_type), intent(inout) :: exception
    character(*), intent(in) :: message
    exception%message = message
  end subroutine throw
  logical function catch( exception, message )
    character(:), allocatable, intent(out) :: message
    if ( allocated( exception%message ) ) then
      message = exception%message
      catch = .true.
    else
      catch = .false.
    end if
  end function catch
end module simple_exception_module
module exception_module
  implicit none
  type, abstract :: exception_type
  contains
    procedure(throw_proc), deferred :: throw
    procedure(catch_proc), deferred :: catch
  end type exception_type
  abstract interface
    subroutine throw_proc( exception, message )
      import
      class(exception_type), intent(inout) :: exception
    end subroutine throw_proc
  end interface
  abstract interface
    logical function catch_proc( exception, message )
      import
    end function catch_proc
  end interface
end module exception_module
Steven_L_Intel1
Thanks - I can reproduce this and will send it on to the developers. Issue ID DPD200414727
Steven_L_Intel1
I expect this bug to be fixed in Update 2 to Parallel Studio XE 2017.
