I have installed the distribution libraries. However, depends.exe states that the application still depends on libifcoremd.dll. Is there a way for the user to siomply receive and run an exe withtout also having libifcoremd.dll.
libifcoremd,dll is installed as part of the redistributables, but sometimes I find I need to log out and in again for Windows to pick up updates to PATH.
You can set the project property Fortran > Libraries > Use Run-Time Library to "Multithreaded" (not "Multithread DLL"), This will use static libraries for MOST things, but OpenMP and coarray support is DLL-only.
