C calling Fortran using stdcall and CVF
Kipling__Michael
I am trying to build and debug some old libraries.  I have a C dll routine calling a Fortran routine from a static library.  The C dll is built using calling convention stdcall, and the Fortran routine is built using calling convention CVF.
The C routine calls the Fortran routine like this:
   dfoefr(&igdfno, fstring[0], iostat, &istats, llen[0]);
and the variables are typed as:
   long igdfno
   char *filspc
   long iostat
   long istats
   size_t llen[1]          (unsigned int - length of filspc)
The Fortran routine call list is:
 SUBROUTINE DFOEFR (IGDFNO, FILSPC, IOSTAT, ISTATS)
 INTEGER IGDFNO
 CHARACTER*(*) FILSPC
 INTEGER IOSTAT
 INTEGER ISTATS
The first two executable lines of code in the Fortran routine are:
      IOSTAT = 0
      ISTATS = 0
I can build the entire solution and step into the Fortran routine up to the 2nd executable line.  If I try to step further the program does not crash, but it jumps back to the GUI.
Rebuilding the libraries using default calling conventions is not an option since there are over 600 routines involved C calling Fortran and vice-versa, and stdcall written directly into the C code.
Suggestions?
Regards, Mike
Steven_L_Intel1
If you are truly using the CVF convention, then you have a problem because that would expect the length of FILSPC to immediately follow the address in the argument list, whereas the C code you have puts it at the end. If you used /iface:stdref instead, then perhaps it would work better, though I see you are passing iostat by value so that too is a problem.
I wonder if the code you posted is not really representative of your actual application.
Kipling__Michael
If I change the Fortran project to use /iface:stdref, the I get the errors like "error #5529: CHARACTER variable 'DESCR' has no length argument in routines with C or STDCALL attribute" each call list character variable in routines which are called by other routines in the library.
If I set the project to /iface:/cvf and set the routine  dfoefr to use /iface:strref , I get the error:
unresolved external symbol _DFOEFR@20 referenced in function _dfc_oefr@12
because the total call list byte length is incorrect.
Mike
FortranFan
What happens if you use /iface:mixed_str_len_arg.  I think I'd to do that once with a legacy application.  Here's what Intel's help says:
Specifies argument-passing conventions for hidden-length character arguments. This option tells the compiler that the hidden length passed for a character argument is to be placed immediately after its corresponding character argument in the argument list.
This is the method used by Compaq Visual Fortran*. When porting mixed-language programs that pass character arguments, either this option must be specified correctly or the order of hidden length arguments must be changed in the source code. This option can be used in addition to other /iface options.
Steven_L_Intel1
I was not suggesting that you change only one file. But you have inconsistencies between the CVF interface and the code you showed. Yes, if you use stdref then it downcases names, so you would also need /names:uppercase. But I think you need to step back and reevaluate what you have, because your description and paraphrase doesn't match the code you showed.
Kipling__Michael
The only way I think I am going to be able to clean all of this up is to update the library code so that I can use the default calling conventions like all of the other C & Fortran code I manage.
Thanks Steve
TimP
Thanks Steve
This looks right, the legacy options seem intended only for use where it isn't possible to update everything, and don't conveniently support ABI mixtures.
