29381 Discussions
C calling fortran with character arguments
rsm2
When calling a Fortran subroutine that has a character argument from C code should the hidden length argument be passed as an int or size_t?
The reason I ask is because I'm having the problem below and I'm not sure if it my code that is at fault or not.
In my C code I have these functions declared
void f_code5_ (char*,int*,int*,int*,int*,int*,int);
void f_code5s_(char*,int*,int*,int*,int*,int*,size_t);
and call them
char * text=0;
text = malloc(20);
strcpy(text,"123x123");
int i1,i2,i3,i4,i5,i6;
f_code5_(text,&i1,&i2,&i3,&i4,&i5,strlen(text));
f_code5s_(text,&i1,&i2,&i3,&i4,&i5,strlen(text));
The f_code5 (f_code5s is the same) is
subroutine f_code5(desc,i1,i2,i3,i4,i5)
implicit none
character*(*) desc
integer i1,i2,i3,i4,i5
character t*255
t = desc
print*,'t5='//desc
return
end
The code aborts (SEGV) on the print statement and if I look at the variable 't' it has the7 characters from desc plus garbage characters to fill it out rather than spaces. The idb debugger shows the hidden argument to have a value of 7 (which is correct) but the command 'whatis desc' returns character*140733193388039 (which is 0x7ffff00000007)
If I call f_code5s immediately before f_code5 then it works. It also works if I remove one of the integer arguments. If I use t=desc(1:len(desc)) then 't' has the correct value.
I am using ifort 10.1.023 for the fortran code and gcc for the C code.
The size is expected as size_t.
TimP
I have run into customers who say that any OS (such as 64-bit linux and Windows and, I suppose, MacOS) where size_t is not the same as int is broken. However, there is a reason why standard C and Fortran ISO_C_BINDING distinguish them. Observing the standard would remove 1 more reason for having to "port" from 32- to 64-bit.
rsm2
Thanks for those answers.
I am still curious as to why
t=desc treats the length as a huge number but
t=desc(1:len(desc)) has the correct length of 7
it suggests to me that the len() function is only pulling 4 bytes off the stack.
I would expect these statements to be equivalent.
I recall a compiler bug, fixed long ago, that could account for this discrepancy. Please try it with a current compiler.
rsm2
Thanks again.
