C++ exceptions broken when linking with ifort (Mac OSX)
Jakob_Schou_J_
I am having troubles using c++ exceptions in a mixed fortran / c++ program. I have written a minimal program that illustrates the problem. The program consist of one fortran file and one c++ file. The fortran code call a function in the c++ file. This c++ function throws and catches an exception.
We have a number of mac computers and when compiling on some computers the program works while on others (most) it doesn't. The exception does not get caught and instead the program terminates with:
libc++abi.dylib: terminating with uncaught exception of type MyExc
forrtl: error (76): Abort trap signal
Image              PC                Routine            Line        Source
libsystem_kernel.  00007FFF8B00A867  Unknown               Unknown  Unknown
Here is the c++ code:
#include <stdio.h>
class MyExc {};
extern "C" void catch_exc_() {
  printf("catch exc\n");
  try {
    throw MyExc();
  catch( ... ) {
    printf("got it\n");
Here is the fortran code:
program test_fortran
print *, "run fortran test"
call catch_exc
end
Here is the build command lines:
ifort -fexceptions -c test_fortran.f90
clang -fexceptions -c catch_exc.cpp -o catch_exc.o
ifort catch_exc.o test_fortran.o -lc++ -fexceptions -o test_fortran
To me this seems like a compiler/tool chain problem. But maybe I am doing something wrong. Any ideas?
pbkenned1
Yes, this works just fine with icc & ifort 15.0 on OSX 10.9.5
$ icc -V
Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.0.077 Build 20141101
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
$ ifort -V
Intel(R) Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.0.071 Build 20140709
$ ifort -fexceptions -c test_fortran.f90
$ icc -fexceptions -c catch_exc.cpp
$ ifort catch_exc.o test_fortran.o -lc++  -o test_fortran
$ ./test_fortran
 run fortran test
catch exc
got it
Patrick
FortranFan
See this discussion: https://software.intel.com/en-us/forums/topic/506739
Jakob_Schou_J_
Please note that I am not trying to use exceptions in fortran code. The exception is thrown and caught (or should be caught) in c++ code.
pbkenned1
I don't think you did anything wrong.  It just doesn't work with the exception handling table generated by the Mac clang compiler.
Just as a sanity/logic check, your examples work fine with icc/ifort on Linux:
[U535143]$ icc -V
Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.1.133 Build 20141023
[U535143]$ icc -fexceptions -c catch_exc.cpp
[U535143]$ ifort -fexceptions -c test_fortran.f90
[U535143]$ ifort test_fortran.o catch_exc.o -o test_fortran -lstdc++
[U535143]$ ./test_fortran
 run fortran test
catch exc
got it
[U535143]$
Patrick
Jakob_Schou_J_
Would it work on mac if I used icc instead of clang?
pbkenned1
I think it should work with icc on MAC, if not, I'd consider it a bug.  Unfortunately I don't have a MAC system to test on, but I'll ask a colleague who does to check it out.
Patrick
pbkenned1
$ icc -V
$ ifort -V
$ ./test_fortran
 run fortran test
catch exc
got it
Patrick
