C fortran interoperability. Changing a value in C and pass to fortran's main program.
glp40hs
Dear,
I want to send a value to a subroutine in c. In subroutine C the value needs to be changed and that change should be kept in fortran. But not work. What do i do?
I greatly appreciate the help!
See example:
---------MAIN FORTRAN---------
program f90callC
use, intrinsic :: iso_c_binding
use interop
implicit none
byte :: i
integer(c_int) :: n
integer(c_int), allocatable, dimension(:) :: vetor
real(c_double) :: val
real(c_float), allocatable, dimension(:) :: array
n=3;   val=3.14
allocate(vetor(n))
allocate(array(n))
write(*,*)'               before:',val
write(*,*)'      ----------------------'
write(*,*)'        vector      array '
do i=1,n
    vetor(i)=2*i-1
    array(i)=i**sqrt(2.)-1
    write(*,*) vetor(i),array(i)
enddo
!void C
call f_function(n,vetor,val,array)
write(*,*)'               after:',val
write(*,*)'        vetor      array '
do i=1,n
enddo
deallocate(vetor)
deallocate(array)
end program f90callC
---------MODULE FORTRAN---------
module interop
    interface inter_c_function
        subroutine f_function(n, vetor, v, array) bind(c, name='c_function')
            implicit none
            integer(c_int), value :: n
            integer(c_int), dimension(n),intent(inout) :: vetor
            real(c_double),intent(inout) :: v
            real(c_float), dimension(n),intent(inout) :: array
        end subroutine
    end interface
end module
---------Subroutine in C---------
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <math.h>
/* Prototype  */
//int fplusint(int k, int m);
float fmultfloat(float k, float m);
//extern void c_function(int n, int *vetor,double v, float *array);
void c_function(int n, int *vetor,double v, float *array) {
int i;
float aux;
    //comandos
    v+=(double)2.0;
    printf( "            Inside C:          %f \n",v);
    for (i = 0; i < n; ++i)
        //vetor+=n;
        vetor=fplusint(n,vetor);
        aux=(float)v;
        array=fmultfloat(aux,array);
        //array*=(float)v;
        printf( "           %d     %f \n",vetor,array);
    m+=k;
return m;
    m*=k;
return m;
jimdempseyatthecove
Fortran passes by reference (pointer) by default (value overrides this).
Your Fortran interface declares v without "value" which is correct.
However, your C function is declared with v as value "double v", which is incorrect.
Change your C function to "double* v" then use one level of indirect on v
*v += 2.0;
Jim Dempsey
glp40hs
Dear Jim Dempsey,
It worked! Is it similar to using c_f_pointer (c_loc (par2), par1)? How would?
Thank you
jimdempseyatthecove
Fortran passes scalar and derived type by reference (default behavior). This is the same as a C pointer. Arrays pass the address of the Fortran array descriptor (however an interface can be declared such that the address of the first cell is passed.
There is no need to do that kind of confusing programming. c_f_pointer is generally used to produce a FORTRAN pointer to something allocated or referenced originating inside the C code. An example is a pointer to an array allocated in C. The c_f_pointer constructs the FORTRAN array descriptor.
Jim Dempsey
glp40hs
Sorry to bother you again. But I need to know how to pass a type fortran to C and
return with new values. I'm new in C. Example:
-- main fortran --
TYPE, BIND(C) :: MYFTYPE
    INTEGER(C_INT) :: I, J
    REAL(C_FLOAT),ALLOCATABLE,DIMENSION(:) :: S ! Are wrong. how is correct in bind(c)?
END TYPE MYFTYPE
type(MYFTYPE) :: mytype
allocate(S(3))
write(*,*)"F(input) :",mytype
call croutine(mytype)
write(*,*)"C(output):",mytype
deallocate(S)
end Program main
-- module fortran --
INTERFACE
    subroutine croutine(testtype) bind(c, name='routine')
        implicit none
        END TYPE MYFTYPE
        type(MYFTYPE),intent(inout) :: testtype
    end subroutine
END INTERFACE
-- header c --
typedef struct {
    int m, n;
    float r(10);
} myctype;
-- c --
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include "intervars.h"
/* C global variables */
myctype MYcTYPE;
void routine(myctype MYfTYPE)
<code to change  MYfTYPE's values and return new values to fortran>
thanks a lot.
jimdempseyatthecove
Look in the IVF documentation, index, array descriptors. Your struct myctype should be replaced with:
[cpp]
struct IVF_ARRAY_DESCRIPTOR_DIM_t
intptr_t nElements;
intptr_t byteStrideBetweenElements;
intptr_t lowerBound;
struct IVF_ARRAY_DESCRIPTOR_t
void* base;
intptr_t element_size;
intptr_t A0_offset;
intptr_t Flags; // 1=allocated/defined, 2 = no deallocation, 4=contiguous
intptr_t nDims;
intptr_t reserved;
struct IVF_ARRAY_DESCRIPTOR_DIM_t Dims[7];
typedef struct
int m,n;
struct IVF_ARRAY_DESCRIPTOR_t ArrayDescriptor;
} myctype;
[/cpp]
Jim Dempsey
jimdempseyatthecove
*** CAUTION ***
IVF Array descriptors are not necessarily the same as MS Fortran, nor GFORTRAN, nor xyz Fortran.
For portability, pass the LOC of the first cell of the array and number of cells.
BTW, in FORTRAN, the right most index has the clostes neighbors (backwards from C).
Jim Dempsey
Jim Dempsey
