C++ -> Fortran pass by reference
Simon_Geard
As I understand it pass-by-reference is not supported from C++ to Fortran is not supported, or at least not part of the language. Nevertheless it seems to enable passing a value to a Fortran routine whose argument is not declared to have the 'value' attribute. The code below illustrates this:
#ifdef FORTRAN
subroutine mysub1(i) bind(c,name='mysub1')
    use iso_c_binding, only: c_int
    integer(c_int), intent(in), value :: i
    write(*,'(a,i0)') 'mysub1: i = ',i
end subroutine mysub1
subroutine mysub2(i) bind(c,name='mysub2')
    integer(c_int), intent(in) :: i
    write(*,'(a,i0)') 'mysub2: i = ',i
end subroutine mysub2
subroutine mysub3(i) bind(c,name='mysub3')
     write(*,'(a,i0)') 'mysub3: i = ',i
end subroutine mysub3
#else
extern "C" {
    void mysub1(int&);
    void mysub2(int&);
    void mysub3(int);
int main (int, char**) {
	int i=3;
	mysub1(i);
	mysub2(i);
	mysub3(i);
	return 0;
#endif
To use it save to a file e.g. example.txt then on a command line do the following:
ifort /c /fpp /DFORTRAN /Tf example.txt /free /Foexample_f.obj
cl /Tpexample.txt /Feexample.exe example_f.obj
Then run it: example.exe
mysub1: i = 2357888
mysub2: i = 3
mysub3: i = 3
The way mysub2 is declared seems to give the required behaviour but I don't think it's standards conforming. So my questions are:
1) what are the problems with doing this?
2) can the current behaviour be relied upon?
3) is it advisable to convert to the declaration used in mysub3?
TimP
In your usage with mysub1, your result will vary between 32 and 64 bit modes, assuming 32 bit default integer.  you have c_intptr_t.  As far as I know, Fortran standard doesn't specify anything about c++ reference, but if your c++ follows the usual rules about interoperability between c++ reference and c pointer, you will be ok.
Your understanding is not correct - pass-by-reference absolutely is supported and is what you get if you omit the VALUE attribute from an argument to a procedure with BIND(C).
IanH
I did have a look at one stage through the C++ standard, and, from what I can remember, I don't think there are rules for interoperability between C pointers and C++ references, and there are explicit differences (references may not require storage and you can't have a pointer to a reference).  I think it is a pretty safe assumption that C++ references are implemented using C pointers when they appear in the formal parameter list of the function - it is possible that practical considerations even require that implementation.  However, I personally do not rely on this assumption.
To highlight, this (mysub4) is the example that is missing from the code in #1, that shows conforming "pass by reference" (informal sense - neither Fortran nor C++ formally describe things that way).
#ifdef FORTRAN
subroutine mysub4(i) bind(c,name='mysub4')
    write(*,'(a,i0)') 'mysub4: i = ',i
end subroutine mysub4
#else
extern "C" {
    void mysub1(int&);
    void mysub2(int&);
    void mysub3(int);
    void mysub4(int*);
    int i=3;
    mysub1(i);
    mysub2(i);
    mysub3(i);
    mysub4(&i);     // Pass address of i.
    return 0;
#endif
First of all, Fortran supports interoperability with C, not C++. To the extent that you can make C++ look like C, it works.
Fortran supports interoperability of argument passing two ways. Assuming an interoperable (BIND(C)) interface,  Assuming that you're not declaring a dummy argument of a Fortran kind that triggers passing by "C descriptor" (TS29113 or Fortran 2015), the standard says:
  • any scalar dummy argument with the VALUE attribute is interoperable with the corresponding formal parameter of the prototype,
  • any dummy argument without the VALUE attribute corresponds to a formal parameter of the prototype that is of a pointer type,
It doesn't talk about "pass by reference", but realistically that's what it means by "a formal parameter of the prototype that is of a pointer type".
