29386 Discussions
COM Server reads data from Access database
jdchambless
Does anyone know if/where a module exists that will allow my to read data from a Microsoft Access database? I am writing a COM server with the COM Server Wizard, and have found how to add and use the Excel functions with the Intel Fortran Module Wizard, but I am unable to figure out where the same would be for the Access library. Any ideas would be appreciated.
Thanks!
Jason C.
Looks like "Microsoft Access 11.0 Object Library" to me (assuming Office 2003).
jdchambless
Wow, I need a break apparently. Thanks for showing me the obvious way, Steve.
jdchambless
Just a quick question if someone has a couple seconds:
How would you use "$Workbooks_GetItem($OBJECT, Index, RHS)" from the Excel 11 Library? I know that $Object can be obtained from a command like:
workbook = $Application_GetActiveWorkbook(excelapp,status)
where "workbook" becomes $OBJECT; and I know that "RHS" is just a return status, but I am unsure how or what the variant "Index" can be given a value. Any suggestions would be appreciated.
Jason C.
