I get intermittent errors reading an 8GB ascii file. Sometimes I get all the way through it and sometimes not. The error shows up by getting spurious info in the read data. Since it happens intermittently it must be some incompatibility between fortran and the operating system, but what??? Heap corruption? Buffering problems? Any help would be appreciated.
Very difficult to say based on just a description. If you see the problem using the current version of the compiler (10.0.026), I suggest filing a support request with Intel Premier Support and the engineers can work with you to diagnose it.
![](/skins/images/8B5EA638CA3587CA763EE9EF53643DD4/responsive_peak/images/icon_anonymous_message.png)
