29277 Discussions
COM .exe Server registration, registration from fortran code
Jonas_H_1
I created an easy COM out-of-process server like in the Fortran Documentation described (adder.exe). Later I want to make calls in 32.Bit Dlls from a COM Object and pipe the calculated Data to a 64 Bit executable.
My Problem is the registration of the COM-Server on another System (for this example: adder.exe). The Docu says that I have to enter following line in cmd.
<var>exe_path</var> /REGSERVER
My problem is, that when I want to deploy the COM-Server on another System this only works when I start cmd.exe with administration rights. Is there another way user without administration rights can deploy a COM-Server, even better is there a way to deploy the COM-Server from the Fortran Source Code which Create an Instance of the Server?
Thanks and greets Jonas
Steven_L_Intel1
I don't think so - my understanding is that COM server registration entails registry modifications that require administration rights. If one does this as part of an install, that usually includes admin rights. I found some interesting discussion at http://stackoverflow.com/questions/3051823/what-is-difference-between-regsvr-and-regserver
