29433 Discussions
COMPILER BUG(?): incorrect "Ambiguous generic interface" error
DataScientist
Valued Contributor I
The following code appears to be standard-conforming,
module container_module
    use iso_fortran_env
    integer, parameter :: lkc = logical_kinds(1)
    integer, parameter :: ikc = integer_kinds(1)
    type :: container_ik(kind)
        integer         , kind  :: kind = integer_kinds(1)
        integer(kind)           :: value
    end type
    type :: container_lk(kind)
        integer         , kind  :: kind = logical_kinds(1)
        logical(kind)           :: value
    end type
end module
module disp_module
    use container_module
    type :: disp_type
    end type
    interface show
    module subroutine show_logical(disp, object)
        use container_module, only: container => container_lk
        class(disp_type)        , intent(inout)               :: disp
       !type(container_lk(lkc)) , intent(in)                  :: object
        type(container(lkc))    , intent(in)                  :: object
    end subroutine
    module subroutine show_integer(disp, object)
        use container_module, only: container => container_ik
       !type(container_ik(ikc)) , intent(in)                  :: object
        type(container(ikc))    , intent(in)                  :: object
    end subroutine
    end interface
end module
end
but Intel ifort 2021.5 generates the following error,
error #5286: Ambiguous generic interface SHOW: previously declared specific procedure SHOW_LOGICAL is not distinguishable from this declaration. [SHOW_INTEGER]
The error however is incorrect because the two interfaces are different.
The issue appears to be with the renaming of the module entities within the interfaces to the same aliases ("container"). If we uncomment the commented lines to use the type names explicitly, then the error is resolved.
This appears to be a bug in ifort unless someone can explain the bizarre behavior observed above. For reference, gfortran is fine with both implementations. The code can be tested here with different ifort and other compilers.
Ron_Green
We're creating a bug report.  Thank you for bringing this to our attention.
FortranFan
For whatever it's worth, I agree the code in the original post appears to conform to the Fortran standard.
Ron_Green
Devorah_H_Intel
The fix is scheduled for 2024.2 release of IFX, planned for July.
DataScientist
Thank you for the fix!
