CVF 6.6C crash and freeze
Nick2
Is it just me...
With a certain project that I work with on CVF 6.6C, while I'm stepping through the code, if I set too many data breakpoints (I think) the development environment will crash. (GPF. Remember those?) If I'm stepping through the code, my machine will randomly freeze for a random amount of time; ie. it takes about 30 seconds to re-draw a window that I click on. The freeze just as randomly goes away (after I F5 the code to the next breakpoint, sometimes I have to F5 it more than once for the problem to go away), and goes away if Iexit the development environment via pressing the PC power-off button. I have an up-to-date computer, and my coworkers have the same problem...
Has anyone else experienced these kinds of problems?
Dishaw__Jim
I haven't used CVF in a quite some time, however, I have experienced freezing while using the Intel Debugger. It seems to occur when I have an "array operation." For example,
REAL, ALLOCATABLE :: my_big_array(:)
ALLOCATE(my_big_array(8192))
my_big_array = 47
When I attempt to step through "my_big_array = 47" the debugger becomes nonresponsive, i.e. if you press F10 to step, the debugger does not go to the next line of code (instead I think the File menu opens up). After some interval, the debugger is working fine. The interesting point is that if I have a breakpoint at the line immediately after "my_big_array = 47" and pressed continue (F5) before "my_big_array = 47", there is never a delay. The delay only seems to occur randomly when stepping.
James, the issue you're seeing has to do with the way the debugger steps over the statement. Your array assignment has lots of instructions, and the debugger may be single-stepping through them. I thimk this is something we improved within the past year.
Dishaw__Jim
That was my guess. What I found unusual was that the amount of time spent was not constant for a given instruction. I guess it is time to download and install the latest.
