CVF "Fast" vs "Check" math library
lklawrie1
초급자
1,132 조회수
I know this is an Intel board...
Recently I was using CVF (6.6C) and recompiled my project using the "fast" math library rather than the "check" (Code Generation tab).
The fast library gave a divide by zero indicating a line that doesn't look like it should be a divide by zero. So, I had to go back to the check version.
Line was:
HConvIn(SurfNum) = 1.31*((ABS(DeltaTemp))**(1./3.))
And I don't think DeltaTemp was an illegal value.
Is this a known problem?
Linda
0 포인트
6 응답
Steven_L_Intel1
1,132 조회수
I am not aware of any "known problems" with the fast math library. With that choice, arguments that are "within normal ranges" are handled fine, but error checking and handling of very large arguments is not done "carefully".
You'll need to see exactly what the arguments to the routines were in order to determine if there's a problem or not.
0 포인트
lklawrie1
초급자
1,132 조회수
I will put that on my "todo" list.
(I am trying to catch up with checkins using CVF right now. Could not get where I was comfortable with IVF results right now so went back to CVF for the interim).
Linda
0 포인트
g_f_thomas
초급자
1,132 조회수
"Recently I was using CVF (6.6C) and recompiled my project using the "fast" math library rather than the "check" (Code Generation tab)."
Normally, whether you use math library "check" or "fast" is set by the project configuration, Debug or Release, respectively, and not via the Code Generation tab.
Anyhow, whatever the configuration, it's worth looking at the CVF docs on SIGNALQQ with SIG$FPE for floating point interrupts and MATHERRQQ with MTH$E_DOMAIN to resolve argument domain errors.
My experience is consistent with Steve's assertion. In this regard, IVF fares better than CVF but YMMV.
Ciao,
Gerry T.
0 포인트
Steven_L_Intel1
1,132 조회수
As far as I know, "check" vs. "fast" is not tied to debug/release. "check" is the default unless you explicitly override it.
0 포인트
lklawrie1
초급자
1,132 조회수
What Steve said has been my observation/recollection.
Linda
0 포인트
g_f_thomas
초급자
1,132 조회수
You're right. "check" is the default whatever the configuration. I personally change it to "fast" in Release, consistent with /Ox. Anyways, whether "ckeck" or "fast", I've yet to see FPE's generated by CVF's math library as claimed.
Ciao,
Gerry T.
0 포인트
응답
