CVF "Fast" vs "Check" math library
lklawrie1
I know this is an Intel board...
Recently I was using CVF (6.6C) and recompiled my project using the "fast" math library rather than the "check" (Code Generation tab).
The fast library gave a divide by zero indicating a line that doesn't look like it should be a divide by zero. So, I had to go back to the check version.
Line was:
HConvIn(SurfNum) = 1.31*((ABS(DeltaTemp))**(1./3.))
And I don't think DeltaTemp was an illegal value.
Is this a known problem?
Linda
I am not aware of any "known problems" with the fast math library. With that choice, arguments that are "within normal ranges" are handled fine, but error checking and handling of very large arguments is not done "carefully".
You'll need to see exactly what the arguments to the routines were in order to determine if there's a problem or not.
lklawrie1
I will put that on my "todo" list.
(I am trying to catch up with checkins using CVF right now. Could not get where I was comfortable with IVF results right now so went back to CVF for the interim).
Linda
g_f_thomas
"Recently I was using CVF (6.6C) and recompiled my project using the "fast" math library rather than the "check" (Code Generation tab)."
Normally, whether you use math library "check" or "fast" is set by the project configuration, Debug or Release, respectively, and not via the Code Generation tab.
Anyhow, whatever the configuration, it's worth looking at the CVF docs on SIGNALQQ with SIG$FPE for floating point interrupts and MATHERRQQ with MTH$E_DOMAIN to resolve argument domain errors.
My experience is consistent with Steve's assertion. In this regard, IVF fares better than CVF but YMMV.
Ciao,
Gerry T.
As far as I know, "check" vs. "fast" is not tied to debug/release. "check" is the default unless you explicitly override it.
lklawrie1
What Steve said has been my observation/recollection.
Linda
g_f_thomas
You're right. "check" is the default whatever the configuration. I personally change it to "fast" in Release, consistent with /Ox. Anyways, whether "ckeck" or "fast", I've yet to see FPE's generated by CVF's math library as claimed.
Ciao,
Gerry T.
