first..
I'm not a programmer..
just 'change some value and run' a very large and old F77 based CFD code "kiva'.
please understand if my problem looks nothing..
everything is OK with CVF, but with IFC,
I can see many warnings and errors
typically,
.kiva3v.f(709): Error 22 : invalid real constant
if(enx(n).lt.1.0e+49) then
occured at exp term..
kiva3v.f(8390): Error 191 : This argument has either the wrong type or no type
spdi41=dmax1(spd(i4,1),0.)
occured at dmax function..
please give me some help..
thanks
typically,
thanks
链接已复制
3 回复数
thanks for your concern.
full project is too large to attach,
if you want, mail me heedory2@kornet.net
and some part is here.
do 90 i4=ifirst,ncells
!error 191:this argument has either the wrong or
!no type
dente=fam(1,1)*spd(i4,2)*mw(1)
den=dente
if(dente.le.0.) den=1.e-10
phi(i4)=fam(2,1)*spdi41*mw(2)/den
90 continue
do 30 i4=ifirst,ncells
sum3(i4)=0.
sum2(i4)=0.
30 continue
sm2max=0.
do 40 n=1,np
if(i4mom(n).gt.999999) goto 40
i4=i4p(n)
if(partn(n).lt.0)partn(n)=1.0
sum3(i4)=sum3(i4)+partn(n)*radp(n)**3
sum2(i4)=sum2(i4)+partn(n)*radp(n)**2
sm2max=dmax1(sm2max,sum2(i4))
!no type
40 continue
if(phidmx.eq.0.0) return
do 5 n=1,nregions
tkemin(n)=1.e+100
tkemax(n)=-1.e+100
epsmin(n)=1.e+100
epsmax(n)=-1.e+100
! error 22: invalid real constant
5 continue
do 15 n=1,nregions
pmin(n)=1.0e+100
pmax(n)=-1.0e+100
15 continue
!no type
den=dente
90 continue
sum3(i4)=0.
sum2(i4)=0.
30 continue
sm2max=0.
do 40 n=1,np
i4=i4p(n)
!no type
40 continue
do 5 n=1,nregions
tkemin(n)=1.e+100
tkemax(n)=-1.e+100
epsmin(n)=1.e+100
epsmax(n)=-1.e+100
5 continue
do 15 n=1,nregions
pmin(n)=1.0e+100
pmax(n)=-1.0e+100
15 continue
