29277 Discussions
CVF6.6 to IFC7.0 having some problems..
heedory
first..
I'm not a programmer..
just 'change some value and run' a very large and old F77 based CFD code "kiva'.
please understand if my problem looks nothing..
everything is OK with CVF, but with IFC,
I can see many warnings and errors
typically,
.kiva3v.f(709): Error 22 : invalid real constant
if(enx(n).lt.1.0e+49) then
occured at exp term..
kiva3v.f(8390): Error 191 : This argument has either the wrong type or no type
spdi41=dmax1(spd(i4,1),0.)
occured at dmax function..
please give me some help..
thanks
I think we'd need to see an actual compilable source. Can you cut it down to something small that we can look at?
Steve
heedory
thanks for your concern.
full project is too large to attach,
if you want, mail me heedory2@kornet.net
and some part is here.
do 90 i4=ifirst,ncells
!error 191:this argument has either the wrong or
!no type
dente=fam(1,1)*spd(i4,2)*mw(1)
den=dente
if(dente.le.0.) den=1.e-10
phi(i4)=fam(2,1)*spdi41*mw(2)/den
90 continue
do 30 i4=ifirst,ncells
sum3(i4)=0.
sum2(i4)=0.
30 continue
sm2max=0.
do 40 n=1,np
if(i4mom(n).gt.999999) goto 40
i4=i4p(n)
if(partn(n).lt.0)partn(n)=1.0
sum3(i4)=sum3(i4)+partn(n)*radp(n)**3
sum2(i4)=sum2(i4)+partn(n)*radp(n)**2
sm2max=dmax1(sm2max,sum2(i4))
!no type
40 continue
if(phidmx.eq.0.0) return
do 5 n=1,nregions
tkemin(n)=1.e+100
tkemax(n)=-1.e+100
epsmin(n)=1.e+100
epsmax(n)=-1.e+100
! error 22: invalid real constant
5 continue
do 15 n=1,nregions
pmin(n)=1.0e+100
pmax(n)=-1.0e+100
15 continue
Looks as if your code assumes that "default real" is double precision. It wouldn't compile with CVF using the default settings either.
Try adding /4R8 to the compile command.
Steve
