Call Fortran DLL into another Fortran DLL
rizzo__rafaela
I need to call a function, e.g. func_private, from a private library at Fortran 90, IMSL, into my main code at Matlab. Then, I created a DLL file with a function that calls func_private. I specified everything as specified by https://docs.roguewave.com/en/imsl/fortran/current/common/readme.html. And, also, I created a header file in C++.
However, when I try to load my dll in Matlab as
loadlibrary example_dll.dll example_header.h alias lib
it gives me the following error message:
Error using loadlibrary
There was an error loading the library "<specified path>\example_dll.dll"
The specified module could not be found.
Caused by:
    Error using loaddefinedlibrary
Apparently, this error occurs if you do not have all the necessary DLLs along with the one that you are using with the LOADLIBRARY function. This error is thrown if any of the dependent DLLs is missing.
Then, I tried to include the missing DLLs into my Fortran DLL, but I could not figure how to do this. An example of my code is described below.
Fortran Code (created as a DLL file):
DOUBLE PRECISION function rizzo_func(a, b, c)
!DEC$ ATTRIBUTES DLLEXPORT, ALIAS : "rizzo_func" :: rizzo_func
DOUBLE PRECISION a, b, c
EXTERNAL FUNC_PRIVATE
include 'link_fnl_shared.h'
CALL FUNC_PRIVATE(a, b, c)
rizzo_func = c
END FUNCTION
Header file, C++:
#ifdef __cplusplus
extern "C" {
#endif
	__declspec(dllexport) double rizzo_func(double* a, double* b, double* c);
#ifdef __cplusplus
#endif
Thanks for any help,
Rafaela Rizzo.
Steve_Lionel
Your Matlab loadlibrary reference makes no sense to me, and the syntax seems to be incorrect (based on the Matlab documentation I can find,)
Do I gather that you are using this method as a way of calling an IMSL routine from Matlab? You may find that this is a violation of the Matlib license agreement.
Yes, it is often the case that "module could not be found" is really that there are missing dependent DLLs, but it can also mean that the called routine isn't exported from the DLL by the specified name.
