Call back Process fortran
massebeuf__vincent
We have a call back process developped in fortran with compaq 32 bits compiler.
This call back process (called CBPROC) is defined as a routine and is used as dummy argument (integer ) by the other routines.
When we perform migration to intel compiler 64 bits , the compilation fails
We tried to define CBPROC as an integer  function
We changed different compilation options and diagnostics : this allows compilation but execution fails
Best regards
V
Arjen_Markus
Can you show us some code that reproduces the problem? Callback routines (or functions) have been a part of Fortran for a long time and there are various possibilities (both within the standard and outside, by means of common extensions). Your description does not give us the details we need to diagnose the problem.
mecej4
As Arjen said, we need to see the code, but here is one guess: one of your routines has a CALL to another routine with CBPROC as an argument, but the calling routine does not have CBPROC declared as EXTERNAL.
massebeuf__vincent
Thanks for your replies.
External has already be tried too, but unsuccessfull.
Here is initial Compaq code :
 SUBROUTINE COMPUT(PROCID,Cbproc,ICODE)
C
 !dec$ ATTRIBUTES DLLEXPORT::COMPUT
 !dec$ ATTRIBUTES ALIAS :'Compute'::COMPUT
C     .. Local Scalars ..
 use dflib
 use kernel32
      INTEGER*4 CBPROC,ICODE
      CHARACTER*24 PROCID
C     ..
C     .. External subroutines ..
      EXTERNAL TEST
 external SETMSG
 external CFILES
 external FFILES
 integer date_time(8)
 character (len=12) rclock(3)
 Character*255 MSG
 CALL TEST(PROCID ,CbProc,ICODE)
      IF (ICODE.EQ.9) THEN
  KCLOSE =1
  ICODE = 7
  CALL FFILES
  MSG="CALCULATION STOPPED BY USER"
  CALL SETMSG(ICODE,MSG,PROCID,CBproc)
  ELSEIF(ICODE.EQ.3) THEN
   ICODE = 5
   MSG="CALCULATION STOPPED WITH ERROR"
 END IF
 CALL CFILES(KCLOSE)
 END
      SUBROUTINE SETMSG(ICODE,MSG,PROCID,CBPROC)
C
C     Called by Fortran
C     for transmit message to VisualBasic
C     --------------------------------------------
 use dfcom
 use dfport
 integer*4 cbproc
     ! Scalar Arguments ..
      INTEGER ICODE
      CHARACTER*255 MSG
 CHARACTER*24 PROCID
 pointer (p1,i_str_out)
 integer*2 i_str_out(255)
 pointer (p2,j_str_out)
 integer*2 j_str_out(24)
 p1=ConvertStringToBSTR(MSG)
 p2=ConvertStringToBSTR(PROCID)
 WRITE(22,20200) ICODE,MSG
 IF (ICODE.NE.9) THEN
  CALL CBPROC(p2,ICODE,p1)
 END IF
 CALL SysFreeString(p1)
 CALL SysFreeString(p2)
C     ..
20200 FORMAT(1X,I2,A255)
      END
Arjen_Markus
Right, in that code CBPROC is both an integer (not a function returning an integer!) and a subroutine. I am not sure I can unravel this all (not right now anyway), but I would declare CBPROC as EXTERNAL and not as an integer. You do use the EXTERNAL statement but unless I overlook it, not for CBPROC.
mecej4
It is a bit humorous to declare a subroutine (which is similar to a C function of type void) as INTEGER, but I guess the compiler just ignores that type attribute when it sees a CALL statement to that subroutine.
There is still insufficient information to even detect that a problem exists. I assume that you have other code with the bodies of subroutines TEST, CFILES and FFILES that you will use to build the DLL. The code shown is accepted by IFort 17.0.6 without complaint. So, where is the problem?
andrew_4619
well if I am reading this correctly passing the function name as a callback you would be passing the address of the function which will be 64 bits address not a 32 bit integer as you have declared it.
mecej4
Regardless of the size of the argument (INTEGER*1 or REAL*16), what is passed on the stack for that argument is its address, which is always the same size (32 bits for a 32 bit EXE/DLL, 64 for a 64-bit EXE/DLL). It is the callee's job to read the value at that address as a single-byte integer or 16-byte real and process the value appropriately.
