Calling Fortran from C
Amir_Filipovic
I have a C-code with calls to Fortran subroutines which doesn't work. I wonder if anybody can guess what I'm doing wrong?
The fortran code isdefined as below:
SUBROUTINE FLYCUR2(datafile,grffile)
!DEC$ ATTRIBUTES DLLEXPORT, STDCALL, REFERENCE :: FLYCUR2
!DEC$ ATTRIBUTES ALIAS: 'FLYCUR2' :: FLYCUR2
CHARACTER*(*) datafile, grffile
It's compiled with Intel Fortran compiler v.10 into a dll. I have tested it with a test example written in C# and it works.
The C code is defined as below:
extern int __stdcall FLYCUR2(char *,int,char *,int);
FLYCUR2(filename1,n1,filename2,n2);
Visual Studio 2008 is used to create a project with theC code. The fortran library (.lib) from the fortrancode is included in "Aditional Depencencies" with the linker.
However when I tried to build the code I get the following error:
Error50error LNK2019: unresolved external symbol __imp__FLYCUR2 referenced in function _print_pages@0GRAFDLL.objGraf_09
Any idea what I'm doing wrong?
DavidWhite
Valued Contributor II
I think your declarations need to be
!DEC$ ATTRIBUTES DLLEXPORT, STDCALL, ALIAS: 'FLYCUR2' :: FLYCUR2
!DEC$ ATTRIBUTES REFERENCE :: DATAFILE, GRFFILE
Jugoslav_Dujic
Quoting - Amir Filipovic
Two things:
  1. STDCALL attribute causes lowercase name decoration, i.e. "flycur2". You can switch it to uppercase by adding ALIAS attribute, but then also use DECORATE, i.e. !DEC$ATTRIBUTES DLLEXPORT, STDCALL, REFERENCE, DECORATE, ALIAS: "FLYCUR2"
  2. In Intel fortran, the default passing of string length arguments is at the end of argument-list, i.e. (char*, char*, int, int). (You can get the old, Compaq Visual Fortran behavior, by specifying /iface:cvf switch or /mixed_str_len_arg, but I advise against it). As David said, you can suppress the length passing entirely by specifying !DEC$ATTRIBUTES REFERENCE:: datafile, grffile (but then you must hard-code the length on Fortran side).
Amir_Filipovic
Quoting - David White
I don't think the problem is in my declaration beacause, as I wrote before, I run the code from C# without any problem. The C# declaration is
[DllImport("sacudll.dll", CallingConvention = CallingConvention.StdCall)]
public static extern long FLYCUR2(String inFile, String outFile);
However I tried the declaration as you proposed and got an error.
anthonyrichards
New Contributor III
Is it because you have defined FLYCUR2 as an integer function, but you reference it as a VOID function? e.g.
Maybe you should write
i=FLYCUR2(filename1,n1,filename2,n2) ?
In which case it should be defined as an INTEGERFUNCTION on the Fortran side.
On the other hand, if you are defining it as SUBROUTINE on the Fortran side, then you should change the prototype to a VOID function on the C side.
Amir_Filipovic
Quoting - Jugoslav Dujic
Two things:
1. I tried to call to "flycur2" in the C-code without success.
2. I also tried to arange call parameters as you proposed without success. Further I tested toomit intparameters in the call- no success.
Amir_Filipovic
Quoting - anthonyrichards
I tried with
externvoid __stdcall FLYCUR2(char *,int,char *,int);
but I got the same error.
TimP
I tried with
Looks like it might be worth while to upgrade the compiler and USE iso_c_binding. The legacy syntax can be made to work, but it's certainly not worth wasting time on it.
Jugoslav_Dujic
I tried with
You seem to have missed my post above. Please read it. (Yes, you do need void as well, but that's a secondary issue.)
edit: ...Oh, and extern "C", if it's a C++ compiler:
extern "C" void __stcall flycur2(char*, char*, int, int);
Steven_L_Intel1
You can't use BIND(C) with STDCALL in our implementation.
The original problem, with the linker error, indicates that the C/C++ code has specified "dllimport" but the library being linked against is not the export library from a corresponding build of the DLL. Note the __imp_ prefix to the name.
Now I notice something interesting. The name generated by building the DLL should be __imp_FLYCUR2 with one underscore before the FLYCUR2, but the linker error message has two underscores. This makes me think that the name as defined in the C/C++ code is actually _FLYCUR2.
Amir_Filipovic
Yes I've read your post and I've tested
extern void __stdcall flycur2(char *,char *,int,int);
flycur2(filename1,filename2,n1,n2);
and I've got the following error
Error1error LNK2019: unresolved external symbol _flycur2@16 referenced in function _print_pages@0GRAFDLL.objGraf_09
I've also tested
extern "C" void __stdcall flycur2(char *,char *,int,int);
and I've got a syntax error.
I've tested so many different options now that I'm beginning to suspect if the linker really seesthe library? The .lib file is included in "Additional Dependencies" and the .dll file is in the working directory. That should be enough - or maybe not??
Steven_L_Intel1
From a Fortran Build Environment command prompt, set default to the folder with the .lib and do this:
dumpbin -exports yourlibrary.lib
where yourlibrary.lib is the name of the export library. What does it show? Note that the names displayed will lack the __imp prefix.
Amir_Filipovic
Here is the result:
Dump of file sacudll.lib
File Type: LIBRARY
Exports
ordinal name
FLYCUR2
Summary
C9 .debug$S
14 .idata$2
14 .idata$3
4 .idata$4
4 .idata$5
E .idata$6
Steven_L_Intel1
Ok - that tells you that the name is upcased from Fortran. Now open that .lib in Notepad and find all instances of FLYCUR. What is the exact symbol shown?
Amir_Filipovic
J__IMPORT_DESCRIPTOR_SacuPC_09 __NULL_IMPORT_DESCRIPTOR
SacuPC_09_NULL_THUNK_DATA FLYCUR2 __imp_FLYCUR2
FLYCUR2 __IMPORT_DESCRIPTOR_SacuPC_09 __NULL_IMPORT_DESCRIPTOR __imp_FLYCUR2
SacuPC_09_NULL_THUNK_DATA SacuPC_09.dll
FLYCUR2 SacuPC_09.dll
Steven_L_Intel1
Great - that looks fine. Note that this is not a STDCALL-decorated name. Now do this for your C++ object:
dumpbin -symbols thisobj.obj > dump.txt
and then open dump.txt in notepad and find all occurences of FLYCUR
Amir_Filipovic
0DA 00000000 UNDEF notype () External | _flycur2@16
Lorri_M_Intel
The Fortran name has only one underscore, and the C code is looking for two.
The Win32 calling convention is that a leading underscore is added to the external name - in this case before the __imp_ is prepended - therefore giving the external name __imp__FLYCUR2 being asked for by the C code.
When you use the ALIAS: "FLYCUR2" the compiler assumes you know EXACTLY what name you want, and so does not put on the leading underscore.
Try adding DECORATE to your DEC$ ATTRIBUTES line. That keyword tells the compiler to treat the "alias" name as a base, and to add any appropriate "decorations" required by the calling convention.
- Lorri
Steven_L_Intel1
Ah, Lorri found the other piece of the puzzle. Actually, looking at what you have, take out the ALIAS entirely since your C++ code is now looking for the symbol that Fortran would create by default when STDCALL is specified.
Amir_Filipovic
Yes, finally!!!! Removing
solved the problem. What a work for such a simple change! But I still wonder why it works when I call it from C#?
Thank you guys for your help!!!
Steven_L_Intel1
It won't work from C# anymore as now the name is wrong. If you want to use it from both C++ and C# you're going to have to use a declaration on the C++ side to set the name to something that C# can use and then go back to using ALIAS.
