29271 Discussions
Calling Fortran subroutine in Fortran DLL from Fortran Main program
avinash_roshan
Hello;
I am new to fortan. I am using Intel fortran81.
I want to know how I can call fortran subroutine defined in a fortran dll file from a main program written in fortran.
Could you provide me a sampleof both(fortran dll and fortran main program).
Thankx in advance.
Avinash
Steven_L_Intel1
I am curious as to why you're using such an old version of the compiler.
There's nothing special you need to do to call a routine provided in a DLL other than link with the DLL's export library. If you have a Fortran executable calling a Fortran DLL, you should build the executable with the /libs:dll option otherwise you might have trouble using I/O or allocatable variables.
Here's a simple sample:
dllsub.f90
subroutine dllsub
!dec$ attributes dllexport :: dllsub
print *, "Hello from dllsub!"
end subroutine dllsub
main.f90
program main
call dllsub
end program main
Build commands:
ifort /dll dllsub.f90
ifort /libs:dll main.f90 dllsub.lib
You can optionally add:
!dec$ attributes dllimport :: dllsub
to the source for main.f90, but it is not required for routines. (It is for imported variables.)
avinash_roshan
Dear Steve;
Thankyou very much for your help.
I am working with a tool called Abaqus. The version I use of this tool requires Intel Compiler 8x.That's why I have to use the old compiler.
Avinash
