Hello;
I am new to fortan. I am using Intel fortran81.
I want to know how I can call fortran subroutine defined in a fortran dll file from a main program written in fortran.
Could you provide me a sampleof both(fortran dll and fortran main program).
Thankx in advance.
Avinash
I am curious as to why you're using such an old version of the compiler.
There's nothing special you need to do to call a routine provided in a DLL other than link with the DLL's export library. If you have a Fortran executable calling a Fortran DLL, you should build the executable with the /libs:dll option otherwise you might have trouble using I/O or allocatable variables.
Here's a simple sample:
dllsub.f90
subroutine dllsub
!dec$ attributes dllexport :: dllsub
print *, "Hello from dllsub!"
end subroutine dllsub
main.f90
program main
call dllsub
end program main
Build commands:
ifort /dll dllsub.f90
ifort /libs:dll main.f90 dllsub.lib
You can optionally add:
!dec$ attributes dllimport :: dllsub
to the source for main.f90, but it is not required for routines. (It is for imported variables.)
dllsub.f90
subroutine dllsub
main.f90
program main
call dllsub
end program main
Build commands:
Dear Steve;
Thankyou very much for your help.
I am working with a tool called Abaqus. The version I use of this tool requires Intel Compiler 8x.That's why I have to use the old compiler.
Avinash
