Calling IVF from C# only via dll?
onkelhotte
New Contributor II
Is there another way to call Frotran Routines (IVF9.1) from C# (VS2005) or do I have to compile my Fortran files as a dll?
I tried to implement following Fortran (as an dll):
Code:
real*8 function EXPFUNCTION (basisA, exponentB)
!DEC$ ATTRIBUTES DLLEXPORT::EXPFUNCTION
implicit none
real*8 basisA, exponentB
EXPFUNCTION = basisA**exponentB
end function EXPFUNCTION
In C# I try to use it that way:
Code:
[DllImport("fortrandll.dll")]
private extern static double EXPFUNCTION(double basisA, double exponentB);
private void buttonFunction_Click(object sender, EventArgs e)
    double ergebnis,basis,exponent;
    basis = 2.4d;
    exponent = 3.7d;
    ergebnis = EXPFUNCTION(basis, exponent);
I copied the dll in the executable path of the C# project. But when I use the EXPFUNCTION I get an exception, that my program had tried to read or write from protected memory (System.AccessViolationException: Es wurde versucht, im geschtzten Speicher zu lesen oder zu schreiben. Dies ist hufig ein Hinweis darauf, dass anderer Speicher beschdigt ist.)
Thanks in advance,
Markus
Message Edited by OnkelHotte on 05-31-200605:20 AM
Message Edited by OnkelHotte on 05-31-200605:21 AM
onkelhotte
New Contributor II
I discovered a solution on my own (okay, a colleague helped a little bit...)
I was not aware of the fact that subroutines and function are called by reference and not by value. So you need to do the following steps in Fortran:
Code:
subroutine FORTRANSUM (summandA, summandB, summeC)
!DEC$ ATTRIBUTES DLLEXPORT::FORTRANSUM
!DEC$ ATTRIBUTES VALUE    ::summandA
!DEC$ ATTRIBUTES VALUE    ::summandB
!DEC$ ATTRIBUTES REFERENCE::summeC
implicit none
integer*4 summandA, summandB, summeC
summeC = summandA + summandB
end subroutine FORTRANSUM
!DEC$ ATTRIBUTES VALUE    ::basisA, exponentB
implicit none
In C# I had to do this:
Code:
    basis = 2.4d;
    exponent = 3.7d;
unsafe private extern static void FORTRANSUM(int summandA, int summandB, int *summeC);
unsafe private void buttonSubroutine_Click(object sender, EventArgs e)
    int a=5, b=9, ergebnis=0;
    FORTRANSUM(a,b,&ergebnis);
It is unsafe code, when you operate with pointers in C#. So you have to declare your Fortran method and the C# method that uses your Fortran methodas unsafe.
Concerning my first question: Do you have to build your Fortran project as a dll? Is that because you have to use two different projects in VS2003+ (one Fortran and one C#)?
Thanks in advance,
Markus
Yes, you have to build the Fortran code as a DLL.
You also need to specify that the Fortran routine uses the STDCALL mechanism, as that is the C# defsult.
